Old 03-01-2011, 13:51   #1 (permalink)
Member: 1059036
Thanks Meter: 57
huawai g 7010 dead
help after sp unlock phone dead and not accepte the flash
log read code
PHP Code:
[QUOTE
COM4 [VCP0selected
module  v3.77
Action
read unlock codes
unlock method
read codes
Model
Huawei-G7010
Checking data
wait...
Phone should be Switched OFF !
Press and HOLD Power button now !
19200 autodetect
Initializing
[6253:8A02:8A00]...
CPUMT6253
chip
0000:0000:000F
status
FF
Connecting at 19200
wait...
Release Power button now !
Phone detectedwait...
HardwareMT6253,E02
Date
2000.00.00
Version
1.0
Version
ESPC113B146SSC
Version
VER.B
115 byte
(sread
imei
3539150
connection Ok
216 byte
(sread
38 byte
(sread
Phone lock
Off
Phone code
2580369
204 byte
(sread
reading data
reading data #2...
188 byte(sread
lock
[1code: + 12345678
lock
[2code: + default
lock[3code: + 1122
lock
[4code: - default
lock[5code: - default
lock[6code: + default
lock[7code: + default
if
code is not accepted by phone:
make full flash backup for emergency case
flash phone with good eeprom file
Power-On phone without sim-card
Power-Off phone
read unlock codes
[/QUOTE
log after sp unlock phone blanck and hang
PHP Code:
[COLOR="White"]COM4 [VCP0selected
module  v3.77
Action
"sp-unlock"
unlock methodsmart fast
Model
Huawei-G7010
Checking data
wait...
19200 autodetect
Initializing
[6253:8A02:8A00]...
CPUMT6253
chip
0000:0000:000F
status
FF
Connecting at 19200
wait...
HardwareMT6253,E02
Date
2000.00.00
Version
1.0
Version
ESPC113B146SSC
Version
VER.B
115 byte
(sread
imei
35391504176919
connection Ok
216 byte
(sread
reading data
warningwrong packet cs
reading data
#2...
building new data...
writing data...
204 byte(sread
reading data
188 byte(sread
building
new data...
writing data...
verifying...
verification Ok
done
[/COLOR
i have flash phone by original flash operation not finish and phone complete dead
PHP Code:
COM4 [VCP0selected
module  v3.77
Device
Huawei-G7010
Checking data
wait...
Actionwrite flash
write
Firmware
Huawei
-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC.BIN_FLNTY6701111184KC__firmware_20110301-093534.B0M.bin
skip
Customization/Language Pack
skip
Customization
skip
Eeprom/ffs
nor area detection
interface:
BROM_DLL_v3.1016.00
Connect
Connecting...
Booting...
bootcode current/expected3.2/3.2
CPU
6253:8A02:8A00
status
FF
bbchip bl ver
FE
NOR flash id
[00C0]: 0098:009E00000000 [TOSHIBATC58FYM7T8C
chip size
16Mb
otp status
/sizeS_DA_NOR_OTP_EXIST/00020000
NAND flash chip
not installed
internal RAM size
00020000
external RAM
S_DA_RAM_ERROR
done
Set baudrate
(921600)...
done
ram test
testing...
ram test passed
===>  detect existing firmware structure...
detect ffs...
ffs offset/size00000000/00000000
detect sec ro
detect custom parameters...
detect project-id...
project-idESPC113B146SSC
detect NOR info
number of areas/bytes to read1:00040000
reading
(HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area
#1 detection...
startup code area #1 detection done
rom info ver07
sw version
project
-idESPC113B146SSC00000000
code offset
00000000
ffs offset
/size [02]: 00DC0000/00240000
rom info structure
: [standardtype (07)
TCL-ID is absent
===>  done
startup code area
#1 check...
done
number of cores
1
loading files
number of areas1
done
write
write core...
errorcan not write flash0FA8:S_FT_DOWNLOAD_FAIL
error
last error0FA8:S_FT_DOWNLOAD_FAIL
Disconnect
done
module  v3.77
Device
Huawei-G7010
Checking data
wait...
Actionwrite flash
write
Firmware
Huawei
-G6620_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC.BIN_FLNTY6701111184KC__fullflash_20110228-193610.B0M.bin
skip
skip
Customization
skip
Eeprom/ffs
nor area detection
interface:
BROM_DLL_v3.1016.00
Connect
Connecting...
Booting...
CPU
6253:8A02:8A00
status
FF
bbchip bl ver
FE
NOR flash id
chip size
16Mb
otp status
NAND flash chip
not installed
internal RAM size
00020000
external RAM
S_DA_RAM_ERROR
done
Set baudrate
(460800)...
done
ram test
testing...
ram test passed
detect ffs...
detect sec ro
detect NOR info
reading
(HW_STORAGE_NOR)...
TCL-ID detection...
startup code area
#1 detection...
rom info ver07
sw version
project
code offset
00000000
ffs offset
rom info structure
TCL-ID is absent
===>  done
startup code area
#1 check...
done
number of cores
1
loading files
number of areas1
done
write
write core...
error
Disconnect
done
Finished
time used2 min 38 sec
Remove
/Install battery now
Old 03-01-2011, 15:17   #2 (permalink)
redpig's Avatar
Member: 941825
Sonork: 100.1584774
Thanks Meter: 34
me too
wait for solution
Old 03-01-2011, 15:29   #3 (permalink)
Member: 610239
Thanks Meter: 15
always use read unlock code method to unlock this model
The Following User Says Thank You to fofchek For This Useful Post:
Old 03-01-2011, 16:27   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@all
please, use test software only according to my instruction: http://forum.gsmhosting.com/vbb/f296...0/#post7015056
Also, as I can see, in some cases software was used with other operation mode and I have to delete test software to avoid user's problems and future misunderstanding.
Once again I ask everybody read instructions before use software !
We will continue with G7010 solution and I hope it will be fixed in short time.
@GSM FREE
charge battery and try to flash phone again
Old 03-01-2011, 18:18   #5 (permalink)
Member: 1059036
Thanks Meter: 57
thanks phone power on and always locked
OM4 [VCP0] selected
module v3.77
Device: Huawei-G7010
Checking data, wait...
Action: write flash
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 46SSC.BIN_FLNTY6701111184KC__ffs_20110301-093800.B0M.bin
nor area detection...
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_EXIST/00020000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
project-id: ESPC113B146SSC
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
startup code area #1 detection...
rom info ver: 07
sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC. BIN_FLNTY6701111184KC
project-id: ESPC113B146SSC, 00000000
code offset: 00000000
ffs offset/size [02]: 00DC0000/00240000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
warning: firmware database can not be loaded
number of cores: 1
loading files...
number of areas: 1
done
write...
write core...
Disconnect...
done
Finished, time used: 2 min 9 sec
Remove/Install battery now !
Old 03-01-2011, 19:27   #6 (permalink)
Member: 130995
I think that after you restore backup phone should be exactly in the same state as before.
At least it should accept original sim card.
We are working now to understand what is the problem with unlock, so if you can pls, keep phone with you.
Also, try to make "read unlock codes" once again now. Pls, post here operation log.
Old 03-01-2011, 19:54   #7 (permalink)
Member: 1059036
Thanks Meter: 57
i tested alwyas code not correct
COM4 [VCP0] selected
module v3.77
Action: read unlock codes
unlock method: read codes
Model: Huawei-G7010
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6253,E02
Date: 2000.00.00
Version: 1.0
Version: ESPC113B146SSC
Version: VER.B
115 byte(s) read
imei: 3539150
connection Ok
216 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 2580369
204 byte(s) read
reading data...
reading data #2...
188 byte(s) read
lock[1] code: + 12345678
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 13 sec
Old 03-01-2011, 19:57   #8 (permalink)
Member: 130995
ok. Thanks for one more test. We will try to release new software fast.
Old 03-02-2011, 19:02   #9 (permalink)
Member: 1059036
Thanks Meter: 57
unlock g6020 done
module v3.77
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C210.M40.04.05
Version: CKT53_12832_09B_HW
116 byte(s) read
imei: 35194804265474
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 38500546
- Power-Off phone
- read unlock codes
Finished, time used: 1 min 0 sec
i wait your update for tested g7010
The Following User Says Thank You to GSM FREE For This Useful Post:
Old 03-02-2011, 22:50   #10 (permalink)
Member: 130995
Yes, we are working to fix problem with 7010 model, but we need some more time.
Old 03-03-2011, 12:40   #11 (permalink)
Member: 1059036
Thanks Meter: 57
unlock g6020 done new verssion
module v3.77
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
New firmware found (v.3.77, database date: 01.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
116 byte(s) read
imei: 35194804273073
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 38848954
- Power-Off phone
- read unlock codes
Finished, time used: 19 sec
http://www.4shared.com/file/H_hti1Ck...W_VODAFON.html
for g7010 i wait your update
Old 03-03-2011, 12:42   #12 (permalink)
Member: 1059036
Thanks Meter: 57
i m sory for 2 post
Old 03-04-2011, 20:50   #13 (permalink)
dipu's Avatar
Member: 177730
Thanks Meter: 11
which cable for G7010 please?
Old 03-04-2011, 22:36   #14 (permalink)
Member: 130995
@GSM FREE
we are really working hard w/o sleep now to improve g7010, hope to give results soon
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-07-2011, 18:29   #15 (permalink)
GSMHASSAN's Avatar
Member: 953232
Thanks Meter: 74
Hi bro
Originally Posted by dipu View Post
which cable for g7010 please?
cable samsung c3303k z3x
The Following User Says Thank You to GSMHASSAN For This Useful Post:
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
HELP Dead 5130 v5.00 N.Schmetz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-08-2011 04:51
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.38307 seconds with 9 queries
