huawei G7010 Error 23 problem i try to unlock Huawei G7010 but the screen was flashing on/off and I try to reflash with backup file , all done but when i try to power on with sim it says Software Error 23 :mad: Any solution for this ? Thanks |
rectore imei original bro imei the erase |
but still error 23 |
Still waiting for Solution !!!!!!! |
Flash the backup , phone must go back to its original state. this model is still under test.coders are working to solve this error. |
As I said in my previous post I have Flash my backup but no luck for me But In Any Way Thanks |
I know, but try again with 'smart write 'enabled , if still the same , uncheck it. the same thing happened to me, the set came alive only after the fifth flash with the backup bro. good luck |
pls i will need some help here,,i forget to do backup on my huawei g7010 before unlock and now i am having porblem with phone,,when i put in a simcard on the LCD say software error:4 and i have try all the 5 flash files in support and still donīt have luck....:mad: COM13 [VCP0] selected module v4.00 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 99SSC.BIN_FLNTY6701111184KC_En_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1044.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0FA4:S_FT_DA_INIT_SYNC_ERROR error: last error: 0FA4:S_FT_DA_INIT_SYNC_ERROR Disconnect... done Finished, time used: 36 sec Remove/Install battery now ! pls if there is any help tell me Quote:
have you done repair the imei ? if not then check |
repair imei Huawei G7010 I have repaired my original imei with full flash but unlock at the moment imposible. COM30 [VCP2] selected module v4.01 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 46SSC.BIN_FLNTY6701111184KC__ffs_20110903-181327.B0M skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ESPC113B146SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC. BIN_FLNTY6701111184KC project-id: ESPC113B146SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 5 min 26 sec Remove/Install battery now ! COM30 [VCP2] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 115 byte(s) read imei: 353915043xxxxx connection Ok 216 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 204 byte(s) read reading data... reading data #2... 188 byte(s) read lock[1] code: + default lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 11 sec Remove/Install battery now ! |
yes bro same problem please help :eek: |
I have same problem here when i flash it it gives error 3 and than if i restore imei to original it gives error 4. format ffs takes it to software error 23.... Phone works fine without Sim card and went Inside menu and rested to factory setting still same. but when start it with a sim card it gives software error. phone is on o2 Uk network originally but doesn't work for o2 either. Hope Infinity team will respond soon. |
i try to unlock Huawei G7010 but the screen was flashing on/off and I try to reflash with backup file , all done but when i try to power on with sim it says Software Error 23 Any solution for this ? Thanks Same problem my phone |
so we are waiting for Update |
