Old 11-04-2017, 12:57   #1 (permalink)
Member: 1837938
Thanks Meter: 25
Huawei LUA-U22 Secure boot flash done by Great CM2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48384731650507543AE635739B
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507543AE635739B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x5F77066EE3A0A986701F35521B559542
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : wt96582_s96582aa51 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3754 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x000000011D880000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 179A
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt96582_s96582aa51.bin
Preloader Sent , Init passed
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLS Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : CUSTOM
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:05:36
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : CUSTOM
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:16
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:06:23
Reconnect Power/Cable!
The Following 14 Users Say Thank You to gsmmizu For This Useful Post:
Old 11-04-2017, 13:34   #2 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 182
Please share your DA boot file boss
The Following 2 Users Say Thank You to meerl329 For This Useful Post:
Old 11-04-2017, 14:09   #3 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
no need any DA file , just connect phone with press both volume keys
try and post result/logs....
The Following 6 Users Say Thank You to syed tuqeer For This Useful Post:
Old 12-20-2017, 13:33   #4 (permalink)
Member: 2285601
Thanks Meter: 13
must add lua-u22 boot file
The Following 3 Users Say Thank You to samsulccp For This Useful Post:
Old 05-20-2018, 04:41   #5 (permalink)
Member: 405871
Thanks Meter: 3
bro plz add da secro file
The Following 2 Users Say Thank You to happylife For This Useful Post:
Old 05-20-2018, 05:33   #6 (permalink)
Unlockinfo's Avatar
Member: 1785930
Sonork: 100.1685640
Thanks Meter: 4,786
Huawei LUA-U22 Secure Boot Tested By Kashi Lucky
free download without pass
just copy paste to C/infinty/MTK/Boot
open Mtk Exe select CPU/Platform
connect phone with power off without any Volume Key Press ,insert usb
Now Connect Perfect
The Following 21 Users Say Thank You to Unlockinfo For This Useful Post:
Old 08-13-2018, 09:26   #7 (permalink)
Member: 2852499
Sonork: 100.1658424
Thanks Meter: 32
Unlockinfo
Now Connect Perfect
Its worked bro thnxxxxxx
The Following 2 Users Say Thank You to citymobile2020 For This Useful Post:
Old 09-19-2018, 15:53   #8 (permalink)
johnmadzeka1's Avatar
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Talking
Now Connect Perfect
Worked for me boss good sharing
The Following 3 Users Say Thank You to johnmadzeka1 For This Useful Post:
Old 10-01-2018, 12:50   #9 (permalink)
Member: 148515
Thanks Meter: 19,536
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
The Following 4 Users Say Thank You to InfinityHelp For This Useful Post:
Old 11-13-2018, 22:21   #10 (permalink)
Member: 2716441
Thanks Meter: 2
Pls how do I flash tecno spark using cm2... thanks
The Following 2 Users Say Thank You to Okon431 For This Useful Post:
Old 11-20-2018, 10:12   #11 (permalink)
Member: 2872145
Thanks Meter: 26
thanks
The Following 2 Users Say Thank You to flash file pat For This Useful Post:
Old 11-20-2018, 12:28   #12 (permalink)
Member: 1677653
Thanks Meter: 2,770
Look for compatible firmware, open cm2 go to flash tab then follow instruction
The Following 3 Users Say Thank You to Yusuf Lawal For This Useful Post:
Old 05-03-2019, 08:05   #13 (permalink)
Member: 2793249
Thanks Meter: 7
no need da file
just hold vol up and down
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 90014A48384731650507525B25D293C5
DRAM configured from IDB!
[eMMC] : FLASH_CID : 90014A48384731650507525B25D293C5
DEV RID : 0x9BCC204A97B982F5144763B7AF02BA07
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:27
The Following 3 Users Say Thank You to mack.gady For This Useful Post:
Old 12-11-2019, 12:11   #14 (permalink)
Member: 2713318
Sonork: 1677721
Thanks Meter: 2
Thanks Brother Its also work for me <3
Old 12-11-2019, 12:49   #15 (permalink)
Member: 1043909
Thanks Meter: 60,964
please always post software operation log text, this may helps other users and developers. thank you
The Following User Says Thank You to YellowBoss For This Useful Post:
Page generated in 0.26286 seconds with 8 queries
