11-04-2017, 12:57 | #1 (permalink) |
Insane Poster Join Date: Nov 2012 Location: Bangladesh Age: 40
Member: 1837938 Status: Offline Thanks Meter: 25 | Huawei LUA-U22 Secure boot flash done by Great CM2 ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507543AE635739B Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507543AE635739B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x5F77066EE3A0A986701F35521B559542 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : wt96582_s96582aa51 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3754 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x000000011D880000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 179A BMT remark not need. Will skip Sending Preloader ... Use : preloader_wt96582_s96582aa51.bin Preloader Sent , Init passed SecCfg Passed , 179A PartCount : 0016 Update PMT by user request Repartition Done! Use FLS Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : CUSTOM Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:36 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : CUSTOM Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:16 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:23 Reconnect Power/Cable! |
The Following 14 Users Say Thank You to gsmmizu For This Useful Post: |
05-20-2018, 05:33 | #6 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,786 | Huawei LUA-U22 Secure Boot Tested By Kashi Lucky free download without pass just copy paste to C/infinty/MTK/Boot open Mtk Exe select CPU/Platform connect phone with power off without any Volume Key Press ,insert usb Now Connect Perfect Last edited by Unlockinfo; 05-20-2018 at 05:38. |
The Following 21 Users Say Thank You to Unlockinfo For This Useful Post: |
08-13-2018, 09:26 | #7 (permalink) |
Insane Poster Join Date: Jul 2018 Location: PAKISTAN
Member: 2852499 Status: Offline Sonork: 100.1658424 Thanks Meter: 32 | Huawei LUA-U22 Secure Boot Tested By Kashi Lucky Unlockinfo free download without pass just copy paste to C/infinty/MTK/Boot open Mtk Exe select CPU/Platform connect phone with power off without any Volume Key Press ,insert usb Now Connect Perfect Its worked bro thnxxxxxx |
The Following 2 Users Say Thank You to citymobile2020 For This Useful Post: |
09-19-2018, 15:53 | #8 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
Worked for me boss good sharing | |
The Following 3 Users Say Thank You to johnmadzeka1 For This Useful Post: |
10-01-2018, 12:50 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
The Following 4 Users Say Thank You to InfinityHelp For This Useful Post: |
05-03-2019, 08:05 | #13 (permalink) |
Junior Member Join Date: Dec 2017 Location: Kampala
Member: 2793249 Status: Offline Thanks Meter: 7 | no need da file just hold vol up and down Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507525B25D293C5 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507525B25D293C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x9BCC204A97B982F5144763B7AF02BA07 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to mack.gady For This Useful Post: |
