09-05-2017, 00:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | huawei mediapad 7 i have a dead huawei s7-721u after update with sdcard read firmware with CM2 qlcm ok but when load file gives me error file ?????? i need a good readed fw .thanks or a good tool that can do the job read and write safetly . Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07BEB0DA ID_BLOCK_I : 008140E1 ID_BLOCK_L : EF19738B2AB0BDA897CC0409D6AD2525 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Huawei ProdName : msm8610 ProdModel : msm8610 Device : msm8610 AndroidVer: 4.3 Manufact. : HUAWEI SysPatch : HuaweiMediaPad DevComTime: 20/10/2014 02:23:52 QLMxCPU : MSM8610 GCSec : NORMAL Done! Elapsed: 00:01:32 Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07BEB0DA ID_BLOCK_I : 008140E1 ID_BLOCK_L : EF19738B2AB0BDA897CC0409D6AD2525 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Huawei ProdName : msm8610 ProdModel : msm8610 Device : msm8610 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm8610__msm8610 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : NON-HLOS.bin [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : vrcb.mbn [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1090 MiB Done! Elapsed: 00:04:01 Reconnect Power/Cable! Loading firmware ... data : D:\huawei s7\MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm8610__msm8610\userdata.img Firmware load error! Firmware incomplete! Some files are missing! Loading firmware ... data : D:\huawei s7\MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm8610__msm8610\MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm8610__msm8610\userdata.img Firmware load error! Firmware incomplete! Some files are missing! |
09-05-2017, 00:19 | #2 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | log of dead device Code: Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0710BDB4 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 3133A955006E9B9671262E37F04BCB03 ID_BLOCK_L : CBBA04A7A83BA320A51045B2B07F6952 Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! |
09-05-2017, 01:42 | #3 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | fw loaded ok but flash fail Code: Device Brand : Huawei Device Manufact.: HUAWEI Device Model : msm8610 Device CPU : MSM8610 Device IntName : msm8610 Device Version : 4.3 CU_SWVer : HUAWEI Device Compile : 20/10/2014 02:23:52 Device ExtInfo : msm8610 Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0710BDB4 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 3133A955006E9B9671262E37F04BCB03 ID_BLOCK_L : CBBA04A7A83BA320A51045B2B07F6952 Pickup loader from firmware package FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07B25AD3 ID_BLOCK_I : 008140E1 ID_BLOCK_L : D0104AB4238FB4B790C50F10DFAA2A22 ID_BLOCK_L : 69E4AA05F699C14247B61BD0D2DDCBF0 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Flash Chain : 29 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : Read back verify failed at sector -1623465688,num sectors 0 Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
The Following User Says Thank You to recan21 For This Useful Post: |
