04-28-2019, 22:47 | #1 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | HUAWEI MediaPad T3 7 3G "BG2-U01"SC7731G'' Need To Remove Password Set mode to : SP [SC773x] eMMC [Android 7.x] Start at : [4/28/2019 / 11:36:58 PM] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [4/28/2019 / 11:38:28 PM] Start at : [4/28/2019 / 11:39:13 PM] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... Normal Mode init Sync... About:- HUAWEI MediaPad T3 7 3G "BG2-U01"SC7731G'' |
04-28-2019, 23:09 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Huawei locked sprd protocol in this device line completely. HardReset and factory FRP code for FRP. |
02-24-2022, 13:13 | #4 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | Here is FDL, you can use with CM2SP2 and I'll upload board firmware soon ****************************/file/by6el...1_FDL.zip/file |
05-04-2023, 15:16 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I guess CM2SP2 boot-pack has everything https://infinity-box.com/?r=100185 |
