02-20-2017, 05:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Huawei S7-721U Not Supported Code: Huawei MediaPad 7 Youth 2 S7-721u Tablet PC Specifications Type Tablet Form Factor Candybar Network 2G: GSM 850 / 900 / 1800 / 1900 MHz 3G: UMTS 850 / 900 / 1900 / 2100 MHz Display 7.0-inch 600 x 1024 pixels 169.4 ppi pixel density 16M colors Capacitive multit-touch (up to 5 fingers) Processor Qualcomm Snapdragon 200 MSM8212 chipset Quad-core 1.2 GHz ARM Cortex-A7 CPU Adreno 130 GPU RAM & Storage 1 GB LPDDR2 SDRAM 4 GB built-in storage microSD slot, supports up to 32 GB Operating System Android 4.3 (Jelly Bean) with Huawei Emotion UI 1.6 Camera 3.2 MP (2048 x 1536 pixels) rear camera HD (1280 x 720 pixels) video recording @ 30fps 0.3 MP (640 x 480 pixels) front-facing camera Data/Connectivity GPRS Class 12, EDGE, UMTS, HSDPA, HSUPA 5.76 Mbps, HSPA+ 21 Mbps Bluetooth 3.0 with A2DP Wi-Fi 802.11b/g/n microUSB 2.0 DLNA Battery Lithium-polymer 4100 mAh Dimensions and Weight 120.6 x 193.4 x 9.9 mm 350 grams Features 3.5mm audio jack Accelerometer Light sensor 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 04AFB11B ID_BLOCK_I : 008140E1 ID_BLOCK_L : A85832CC6BF7FCEFD88D474897D2626A ID_BLOCK_L : 6A19A7060B9AC44144B3E4DDD7DEC8F3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : msm8610 ProdModel : msm8610 Device : msm8610 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm86 10__msm8610 ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Send report to mail : [email protected] with title "QFW" ! Info : Device is not supported yet! Send log and report.log to support! Include device info also! QLM_report Huawei S7-721u |
