11-30-2008, 11:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Huawei t156 ufone unlocked infinity module v1.56 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sta_20081130-151520.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sec_20081130-151524.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081130-151532.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 41 sec Remove/Install battery now ! THANKS TO INFINITY |
The Following 8 Users Say Thank You to kasrawiz For This Useful Post: |
11-30-2008, 13:33 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kasrawiz Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
The Following 6 Users Say Thank You to InfinitySupport For This Useful Post: |
06-28-2009, 12:28 | #8 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 612770 Status: Offline Thanks Meter: 33 | hi pls help me ufone t156 no boot COM3 [VCP0] selected module v1.64 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820011 loading... error: can't run preloader: 01 Release Power button now Boot Failed Finished, time used: 5 sec Remove/Install battery now ! |
06-28-2009, 12:28 | #9 (permalink) |
Member: 612770 Status: Offline Thanks Meter: 33 | all COM3 [VCP0] selected module v1.64 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820011 loading... error: can't run preloader: 01 Release Power button now Boot Failed Finished, time used: 5 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ejazakbar905 For This Useful Post: |
06-28-2009, 12:33 | #10 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
06-28-2009, 13:26 | #13 (permalink) |
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | |
07-09-2009, 11:05 | #15 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 711402 Status: Offline Sonork: 100.1580671 Thanks Meter: 656 | Quote:
This is not new chip its old chip not new secrity Because i had tried too much with the latest version its not connecting but still LOGS HERE COM3 [VCP0] selected module v1.60 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 18 sec Remove/Install battery now ! | |
The Following User Says Thank You to zeeshanawan For This Useful Post: |
SagemDD add HUAWEI T156 ufone Please | umarnlw | Infinity-Box | 4 | 12-18-2009 14:08 |
Huawei t156 not suppoted infinity box | mobiletuch | Infinity-Box | 3 | 11-08-2009 14:05 |
Huawei t156 ufone | MobilesDoctor | SAGEM JTAG UNLOCKER | 29 | 08-25-2009 14:49 |
Ufone Huawei T156 Succesfully unlocked | .::BHATTI::. | Infinity-Box | 18 | 06-22-2009 16:08 |
HUAWEI T156 UFONE reset code plz urgent | asif_ae | Various | 1 | 12-26-2008 21:57 |
