Old 08-16-2008, 18:12   #1 (permalink)
Satyam321's Avatar
Member: 269198
Thanks Meter: 78
huawei t158 unlock success
hi all,,
and thanks infinity
Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe
Loading data, wait...
[Infinity Box] v1.51
S/N:
Wait...
Current model: Huawei-T158
Ready
COM3 [VCP0] selected
Device: Huawei-T158
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-sta_20080816-210541.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-sec_20080816-210544.B1E.bin
reading [eeprom-complete]...
file saved: C:\Documents and Settings\Administrator\Desktop\Huawei-T158_eeprom-complete_20080816-210552.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 42 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
The Following 2 Users Say Thank You to Satyam321 For This Useful Post:
Old 08-17-2008, 13:29   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 11-17-2008, 11:08   #3 (permalink)
Member: 73455
Thanks Meter: 23
what cable should we use for this unit? i have here but no cable can be fitted from my infinity box package...
Old 11-17-2008, 11:38   #4 (permalink)
Member: 130995
Cable name: LG-C2500
Old 12-26-2008, 11:12   #5 (permalink)
Member: 73479
Sonork: 100.1581683
Thanks Meter: 55
Is the cable included in the infinity or pls gives us pin out to make the cable.
Thanks.
Old 12-26-2008, 12:40   #6 (permalink)
Member: 130995
Thanks.
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-26-2008, 12:52   #7 (permalink)
Member: 73479
Sonork: 100.1581683
Thanks Meter: 55
@InfinitySupport
Thank you.
for replying please what pack of the software do i down load that supports this modle for unlocking
HUAWEI T158
THANK YOU VERY MUCH.
Old 12-26-2008, 13:46   #8 (permalink)
Member: 130995
Dearest Friend,
Please, download and install all latest updates, it is very important to use latest software for all models !
Old 05-13-2009, 08:53   #9 (permalink)
Member: 322855
there are new huawei t158 models impossible to unlock l have many piceas pls infinity help.
Old 05-13-2009, 08:55   #10 (permalink)
Member: 73479
Sonork: 100.1581683
Thanks Meter: 55
t 158
Hi
There are new phones t158 we cant unlock .......... any solutions
Old 05-13-2009, 13:26   #11 (permalink)
Member: 130995
@ngash
@4 u man
Try to select model Sagem-my150x and make unlock.
What is the results ?
Old 05-14-2009, 09:01   #12 (permalink)
Member: 73479
Sonork: 100.1581683
Thanks Meter: 55
T158 unlocking all
I m unlocking all T158 all .........................
Old 05-14-2009, 17:10   #13 (permalink)
Member: 320858
Sonork: 100.1602961
Thanks Meter: 25
how
how do u unlock all while we cant.
share bro
Old 05-22-2009, 07:00   #14 (permalink)
Member: 73479
Sonork: 100.1581683
Thanks Meter: 55
@Alfarouk
Hi.
There is also one model no one can T158 unlocking.
Old 05-22-2009, 10:42   #15 (permalink)
papsnew's Avatar
Member: 390521
Thanks Meter: 57
THanks for t158 unlock
NOw t158b unlock PLEEASE!!!
Huawei t158 unlock ok on vygis el-safwa VygisToolbox 2 12-19-2014 16:51
Huawei t158 unlocking error laxman kumar Infinity-Box 1 11-05-2009 11:51
HUAWEI T158 Unlocking all 4 u man Infinity-Box 2 05-14-2009 12:58
kp100 and huawei T158 unlock ok... ZIYAAD STRYKER Infinity-Box 0 02-14-2009 05:41
1000 pieces of Huawei T158 unlocked successfully ericnite101 Infinity-Box 1 11-24-2008 07:53
Page generated in 0.29307 seconds with 9 queries
