01-15-2009, 12:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Huawei T161L unlocked :D COM5 [VCP16] selected module v1.59 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090115-155953.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090115-155954.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090115-160000.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090115-160020.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 64 sec Remove/Install battery now ! |
The Following User Says Thank You to kasrawiz For This Useful Post: |
01-16-2009, 00:06 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
Huawei t161L unlock Success | Imran Bhatti | Infinity-Box | 5 | 02-10-2009 22:27 |
huawei t161l unlock done | nadim electro | Infinity-Box | 2 | 01-28-2009 13:50 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
huawei T161L unlock down all network by infinity box | aleem26 | Infinity-Box | 1 | 01-19-2009 15:11 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
