12-16-2008, 10:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>>> LG KE770 Unlocked Ok <<<< COM4 [VCP0] selected module v1.58 Device: LG-KE770 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static_20081216-151119.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-static2_20081216-151119.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-security_35030526000000100_20081216-151120.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20081216-151121.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01F8 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 16 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KE770P40FL-61-V10b-505-01 JAN 11 2008+0 original imei: 35586201000000200 new imei: 35525401630252 imei verification Ok Done Finished |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
12-16-2008, 21:21 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
>>>> LG KF510 Unlocked Successfully <<<< | zeel_zeel | FuriousGold | 2 | 01-23-2009 15:51 |
>>>> BSNL-G200CF Unlocked Successfully <<<< | zeel_zeel | Infinity-Box | 1 | 12-02-2008 10:08 |
>>>> Samsung T519 Unlocked Successfully <<<< | zeel_zeel | NSPRO | 1 | 11-22-2008 09:21 |
<<<< LG KG225 Unlock ok with Infinity >>>> | dog_baby | Infinity-Box | 1 | 01-19-2008 08:32 |
>>>> error while unlocking L6i <<<< | keaelite | Ultima Box Light | 1 | 04-28-2007 06:26 |
