11-05-2009, 16:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In My Laptop Age: 16
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | Need Pinouts For This Set I hv tried with Given Pinouts in My dadabase folder but not working could some1 provide working pinouts here is pinouts that i tried http://i34.tinypic.com/6jko4o.jpg http://i34.tinypic.com/aw6utw.jpg br |
11-05-2009, 16:42 | #2 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
all pin out are there regards, | |
11-05-2009, 16:51 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Swap RX TX If Not Working Than Try This Sure Its For U hehe!! Regars UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
11-05-2009, 17:07 | #6 (permalink) | |
regards, | |
11-05-2009, 17:32 | #7 (permalink) |
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | @toutou http://forum.gsmhosting.com/vbb/show...69&postcount=5 thnx guys i have done it COM13 [VCP0] selected module v2.94 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:EBC1:42B6 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: M220_PCB01_GPRS_MT6226_S01.D800A_V02_06_FO.BIN ver. sw 2: D800A_V02.06_FO, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: M220_PCB01_GPRS_MT6226_S01.D800A_V02_06_FO__ffs... file saved: C:\Documents and Settings\GSM DOCTOR\Desktop\M220_PCB01_GPRS_MT6226_S01.D800A_V0 2_06_FO__ffs_20091105-212100.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done Finished, time used: 227 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Regardz Shahzad |
Need pinout for this model tv2008 | toto05 | Chinese Models & Cloned Phones | 2 | 09-13-2010 12:59 |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
I need pinout for this phone with TV | zoki | Infinity-Box | 2 | 04-14-2008 14:45 |
i need pinout for this module | joni_rajpura | Infinity-Box | 6 | 03-24-2008 21:27 |
I need pinout for this phone.... | zoki | Various | 1 | 10-31-2007 16:04 |
