Huawei-T616i from jaaz unlock Huawei-T616i from jaaz unlock 100%ok COM9 [VCP0] selected module v1.61 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090207-175012.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z125_eep65535.cfg error: can't load database v.13 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090207-175012.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090207-175014.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090207-175020.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 33 sec Remove/Install battery now ! |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
