06-23-2016, 13:09 | #17 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2370100 Status: Offline Sonork: 1681551.mobile Thanks Meter: 4 | Card found : S/N : CFF9945E , v0130 Chinese Miracle II [MTK module] v 1.49 Operation : Format FileSystem [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741C0100705A3155528 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
07-09-2016, 23:46 | #18 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748456 Status: Offline Thanks Meter: 32 | any good news about unbricking TAG-L21? I bricked mine after i used v1.49 and make check booting with [6571....6795] and alcatel After this the device is shown by the software but doesnt power on |
09-08-2016, 13:17 | #23 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Revive that sample is easy tak. Make "Init preloader" with that file and power on phone |
The Following 11 Users Say Thank You to JayDi For This Useful Post: |
09-10-2016, 19:54 | #30 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Hello bro u r in wrong place...its not a Mirical Box Support Section.. This is Infinity Box CM2 (Chines Mirical 2) Support Section if u need help in CM2 support section then just buy a CM2 dongle and yes CM2 is a Tension Free Tool But only.. when u have CM2 and a Little Brain |
