01-28-2015, 01:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: InFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | ♦♦♦♦HUAWEI Y330-U05 [MT6572_SECURE BOOT] !Read Flash! ::PERFECT::[First in World]♦♦♦♦ Secure Boot / Secure eMMC Read All Perfect READ INFO ((NAND/EMMC)) ♦♦No Read♦♦ Code: Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! ♦♦Read Perfect♦♦ / Unique in the world Code: Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473C05D4F8F291DD [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:09 Reconnect Power/Cable! READ FLASH ((3.7 Gb)) Code: Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473C05D4F8F291DD [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Saved to : E:\6572_Temp_dump.ispff Done! Elapsed: 00:25:48 Reconnect Power/Cable! In a Few Minutes hang link of FLASH!!!! >>MaO<< Krazy_LaB |
The Following 5 Users Say Thank You to maomatrix For This Useful Post: |
01-30-2015, 15:29 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Got the dump, thanks! In near versions will be Firmware Read/Write support for such CPU's/Phones and other improvements. |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-30-2015, 20:23 | #4 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Ok I wait for NEW Version.. need function to WRITE firmware in 6571 NAND Too...!!! Again THANKS for you software.. PD: I hope if you want to sendme a beta in this case..!!!! Thanks in Advance.. >>MaO<< |
05-21-2015, 15:28 | #11 (permalink) | |
Major Poster Join Date: Sep 2014
Member: 2264372 Status: Offline Thanks Meter: 3 | Question? Quote: | |
05-21-2015, 16:35 | #12 (permalink) | |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Quote:
Bro.. this flash is in OFFICIAL SUPPORT of INFINITY....Download and flash whit >CM2<.. maybe fix you problem... And this flash work fine.... | |
The Following User Says Thank You to maomatrix For This Useful Post: |
05-24-2015, 21:01 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Online Sonork: 100.1600061 Thanks Meter: 429 | how to read file huawei g610-u20 read file reading error boot secure here is a log Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
05-25-2015, 16:30 | #14 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Bro, if soft face this error... please.. please.. select in CPU/PLATAFORM/WORKMODE the option "SP: Select Model [6571...6573]" and click in Huawei Secured G610/Y330 and again READ FLASH.......no more Last edited by maomatrix; 05-25-2015 at 16:38. |
