04-07-2016, 20:19 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | huawei Y520-u22 dead after flash Operation : Flash [ v1.44 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611102AC5755A4B2E1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Yasir Ali For This Useful Post: |
04-08-2016, 06:05 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Quote:
Please read info ((complete)) before do any operation... Fix easy...download original firmware and flash whit CM2 scatter.. or read DUMP for other phone and write... | |
The Following 3 Users Say Thank You to maomatrix For This Useful Post: |
04-08-2016, 21:00 | #4 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | i will try with huawei original file on support but same error any one have other file plz give me link.... |
The Following User Says Thank You to Yasir Ali For This Useful Post: |
04-08-2016, 23:14 | #5 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | there is new version for y520-u22 thats why its dead .... scatter file... https://mega.nz/#!rE0CnSqI!4qXoeUII6...AD3MZ20ELT7vW0 bin file https://mega.nz/#!hIYn1Qia!m_hE-aAQl...O3uJRl0HQ82rdc |
The Following 4 Users Say Thank You to abo anas zayan For This Useful Post: |
04-09-2016, 08:08 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | try with this preloader |
The Following User Says Thank You to rehmani For This Useful Post: |
04-09-2016, 11:27 | #7 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: OneTheWay
Member: 2554807 Status: Offline Thanks Meter: 612 | 100% tested Quote:
100% TESTED BY ME LINK : http://forum.gsmhosting.com/vbb/f715...e-box-2075976/ | |
The Following 5 Users Say Thank You to Nishan_Raja For This Useful Post: |
04-09-2016, 16:48 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I will ban all idiots, who provide here any sh*it, also all those, who press them "thanks". If you can't solve it and can't read logs - then better give phone someone, who can do that. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
04-09-2016, 17:00 | #11 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 894846 Status: Offline Sonork: ajmal Thanks Meter: 111 | boss ur phone need b111 file or b112 these two files easly can recover ur phone i have miracle backup of final firmware b112 i wil try to upload on 4shared so just wait |
The Following User Says Thank You to ajmal_khan713 For This Useful Post: |
04-09-2016, 17:17 | #12 (permalink) | |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | Quote:
04-09-2016, 19:10 | #14 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | thanks of all my problem solved flash this file and hard rest now set working https://mega.nz/#!rE0CnSqI!4qXoeUII6...AD3MZ20ELT7vW0 |
The Following 2 Users Say Thank You to Yasir Ali For This Useful Post: |
