HUAWEI Y600-U20 & lenovo A319 Hello dear friends there are Huawei Y600-U20 and Lenovo A319 that have not swich on pb.Coustmers say that are swiched off itselfs.I have tried flash both phones but evry time its give error Y600-U20 LOG Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 74 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND : Error : DA init Failed! Error code : 0x4 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! AND A319 log Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 74 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040505A277C43251 DA Stat : v4.2 on BBID : 0x88 Error : DA init Failed! Error code : 0x5 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! Have try differents files and also Flash Tool but no results.Help me please Thanks |
eMMC is dead. Change to new one or try resolder that. |
no i have also tried to read information in A319 its same failed its been a bug.which should be done in next update i think. |
Need start from cable and battery. |
Then have no idea. Both models boot and work with CM2. |
HUAWEI Y600-U20 Прошивка // imei repair Operation : Read Flash [ v1.40 ] Code: 1. Power Off Phone , Remove battery , Insert back Code: 1. Power Off Phone , Remove battery , Insert back |
need good fw dump of this model , pls |
