02-28-2021, 17:59 | #4 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: lagos nigeria
Member: 1535920 Status: Offline Thanks Meter: 31 | Quote:
1 run cm2mt2 and check sSla 2 connect the device in brom mode 3 perform hardware report and identify when successful 4 intialise memory through memory tool i read nram and oeminfo partions ii erase oeminfo partion 5 power on the device and enable and add password to the device 6 Write the read oeminfo partion (4i) 7 unlock the with password instead of Huawei id. Post logs for further help Sent from my Redmi Note 5 using Tapatalk | |
03-01-2021, 23:28 | #8 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
The Following User Says Thank You to gile@gile For This Useful Post: |
03-02-2021, 10:34 | #10 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, you can convince your client that it is necessary and it is faster and if you do not convince him you will have to do it manually and the process is much slower, there are no more options, greetings. BR |
03-04-2021, 16:26 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | In that case - correct, no luck. BUT! it good idea to try something more, if device connect in preloader mode. try tick "Force BROM" and check. |
