11-28-2008, 16:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Blackside Age: 45
Member: 58536 Status: Offline Thanks Meter: 65 | mot w208 after flashing is dead... after flashing my motorola w208 is dead.. i flashed it with followig files: W208_0.0.58_Main_K1.34M.bin W208_0.0.58_LP_T08_Cz_Mg_Pl_Slovensko.34P.bin W208_Flex_DF_00T_DEF_retail.34F.bin and when i will it flashing, always "write error at..." what is the problem?? please help me infinity team! thnx! b. |
01-15-2009, 19:23 | #7 (permalink) |
No Life Poster Join Date: Jun 2004 Location: egypt cairo - italy roma Age: 40
Member: 68882 Status: Offline Sonork: 1577247 Thanks Meter: 111 | phone alive again with hmodule COM8 [VCP0] selected Device: Locosto 8m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89887400010001:89887400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data... Read data done Check data... Check data done Writing... Area: Firmware flash: 89887400010001:89887400000000 Write: Firmware Writing done Finished, time used: 770 sec Remove/Install battery now ! |
The Following User Says Thank You to abcrino50 For This Useful Post: |
01-15-2009, 19:52 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: turkey
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | COM8 [VCP0] selected module v1.29 Device: Locosto 8m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 11 sec Remove/Install battery now ! please help me |
01-16-2009, 12:08 | #11 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | i have problem flash mot w208 to i try moto01.exe phone come to me with white screen n show ffs_formating.... flash get complete but still not solve the white screen n still show ffs_formating this is the log Remove/Install battery now ! COM8 [VCP0] selected Loading data, wait... Device: W208 Press and Hold Power button... rom version: 0502 Connecting... booting... finalizing... working, one more step... flash: 0089:8874 Intel T 8Mb reading eeprom... done file saved: C:\Program Files\InfinityBox\Moto01\backup_W208_eeprom_200901 16-171231.34E.bin reading ffs... done file saved: C:\Program Files\InfinityBox\Moto01\backup_W208_ffs_20090116-171259.34E.bin Finished, time used: 42 sec Remove/Install battery now ! Loading file v.02... W208_0.0.56_Main_K2_1165853420_2006-Dec-12.34M.bin loaded Loading file v.02... W208_0.0.56_LP_H02_Indonesia_En_Th_Vn.34P.bin loaded Loading file v.02... W208_Flex_AC_007_102_retail.34F.bin loaded COM8 [VCP0] selected Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W208 Checking data, wait... loader: default version Connect... Press and HOLD Power button... rom version: 0502 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 661 sec Remove/Install battery now ! btw ... i will try flash with hmodule.exe n will post result regards notgood |
01-16-2009, 13:02 | #12 (permalink) |
Member: 355635 Status: Offline Thanks Meter: 53 | flash with hmodule.exe, n already try flash with all firmware ini support still can't solve the problem, the phone still white screen n show ffs formating... then restart n white screen n show ffs formating...again... this is the log Device: Locosto 8m Loading file v.02... W208_0.0.56_Main_K2_1165853420_2006-Dec-12.34M.bin loaded COM8 [VCP0] selected module v1.30 Device: Locosto 8m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89887400010001:89887400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 89887400010001:89887400000000 Write: Firmware Write done Finished, time used: 20 sec Remove/Install battery now ! Loading file v.02... W208_0.0.58_Main_K2.34M.bin loaded COM8 [VCP0] selected module v1.30 Device: Locosto 8m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89887400010001:89887400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 89887400010001:89887400000000 Write: Firmware Write done Finished, time used: 366 sec soo... how to solve my problem thx in advance regards notgood |
01-16-2009, 16:56 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone has "formatting" message at LCD, reboot and show "formatting" again it may be a result of damaged or bad soldered flash chip. Try to flash phone with W208_repair_image_K2_0.4.63.80M.bin then make sp-unlock. Power on phone and wait several minutes. If problem still exist you need to open phone and check it's hardware. |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
01-16-2009, 18:50 | #14 (permalink) |
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | phone write allways "phone is hacked" and restart how to solved this problem. ı unlock after phone is hackerd. sir my log. COM8 [VCP1] selected module v1.30 Device: Locosto 8m "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 12 sec Remove/Install battery now ! |
p730 after flash is dead | imanpanahi | Samsung Hardware Repair | 2 | 08-30-2006 11:00 |
6270 after flash is dead | oki papa | Nokia Base Band 5 ( BB-5 ) | 2 | 07-08-2006 12:52 |
8310 after flash is dead | nadeem786 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 08-27-2003 17:49 |
help me my s 40 after flash is dead | lelik | NON Siemens Brand (ODM Phones) | 2 | 04-24-2003 19:04 |
Mitsubishi MT-345@i after flashing is DEAD.... | -=G3=- | Mitsubishi | 2 | 07-06-2002 13:40 |
