11-09-2008, 09:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 39
Member: 151871 Status: Offline Thanks Meter: 71,423 | HUH!! strange Problem Please see it . i have got a mobile with user lock ( security code ) problem so i try to solve it with useing read code etc i also do format ffs but no luck . i do mostly all things that infinity can but still user code . so here is i am uploading Eeprom of that mobile so Please check it and tell me how to solve this problem with thanks Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.66 S/N: 1E6E:0111 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/8/2008 5:40:32 PM] ==== COM6 [VCP0] selected module v2.66 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858DFX_6226b_MULTI_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 159 warning: wrong packet cs 159 of 159 items cleared building list... done 0 items remains Finished, time used: 21 sec Remove/Install battery now ! ==== log: [11/8/2008 5:43:05 PM] ==== COM6 [VCP0] selected module v2.66 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! ==== log: [11/8/2008 5:43:32 PM] ==== COM6 [VCP0] selected module v2.66 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! ==== log opened: [11/8/2008 5:44:58 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.66 S/N: 1E6E:0111 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [11/8/2008 5:45:07 PM] ==== COM6 [VCP0] selected module v2.66 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858DFX_6226b_MULTI_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (27 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 105 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/8/2008 5:52:18 PM] ==== COM6 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2A06C4A3.[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN_CE878FB7].rpl identification#1 detection finished device-id: 2A06C4A3 identification#1 protocol ver: 04 ver. sw1: M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN ver. sw2: M858DFX_6226b_MULTI_11H, 48707831 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]_20081108-175413.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_2A06C4A3_M858DFX_MULTI_PCB01_GPRS_MT6226 _S01.M858DFX_6226B_MULTI_11H.BIN_CE878FB7_20081108-175426.B0X.bin Finished, time used: 115 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log opened: [11/9/2008 12:22:08 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.66 S/N: 1E6E:0111 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [11/9/2008 12:22:24 PM] ==== COM6 [VCP0] selected module v2.66 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 1 sec Remove/Install battery now ! ==== log: [11/9/2008 12:22:37 PM] ==== COM6 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "user code" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2A06C4A3.[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN_CE878FB7].rpl identification#1 detection finished device-id: 2A06C4A3 identification#1 protocol ver: 04 ver. sw1: M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN ver. sw2: M858DFX_6226b_MULTI_11H, 48707831 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]_20081109-122509.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: 98004900000002:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_2A06C4A3_M858DFX_MULTI_PCB01_GPRS_MT6226 _S01.M858DFX_6226B_MULTI_11H.BIN_CE878FB7_20081109-122525.B0X.bin Finished, time used: 156 sec Remove/Install battery now ! ==== log: [11/9/2008 12:29:20 PM] ==== COM6 [VCP0] selected module v2.66 Action: user code unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858DFX_6226b_MULTI_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0 3 4 5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (27 tries), read flash and send to support error: can't read required lock data error: operation failed ! Finished, time used: 104 sec Remove/Install battery now ! ==== log: [11/9/2008 12:31:48 PM] ==== COM6 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 6 sec Remove/Install battery now ! ==== log: [11/9/2008 12:32:04 PM] ==== COM6 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2A06C4A3.[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN_CE878FB7].rpl identification#1 detection finished device-id: 2A06C4A3 identification#1 protocol ver: 04 ver. sw1: M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN ver. sw2: M858DFX_6226b_MULTI_11H, 48707831 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M858DFX_MULTI_PCB01_GPRS_MT6226_S01.M858DFX_6226B_ MULTI_11H.BIN]_20081109-123432.B0E.bin flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: 98004900000002:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_2A06C4A3_M858DFX_MULTI_PCB01_GPRS_MT6226 _S01.M858DFX_6226B_MULTI_11H.BIN_CE878FB7_20081109-123443.B0X.bin Finished, time used: 156 sec Remove/Install battery now ! BR Faisal_Computer |
11-09-2008, 09:22 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, It can not be true that after complete format user code can not be deleted. What codes you have tried ? What text you see at phone LCD ? |
11-09-2008, 09:32 | #3 (permalink) | |
Member: 151871 Status: Offline Thanks Meter: 71,423 | Quote:
and brother yes i never ever seen this type of problem here Please see that pic and eeprom files Br Faisal_Computer | |
11-09-2008, 11:18 | #7 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,423 | Imei changed but problem same COM6 [VCP0] selected module v2.66 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 353796023226604 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:81BE:7116 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858DFX_6226b_MULTI_11H Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification done: 35379602322660 Finished, time used: 12 sec Remove/Install battery now ! i also do Repair Security Area but same problem BR Faisal_Computer |
11-09-2008, 11:32 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, In fact after ffs format all user settings should be set to default values (user code too). But as I can see some phones become in permanently blocked state if you make format and did not set correct imei value (this problem was found and well discussed for some Fly models, MT62xx based). What to do now: read flash and send to [email protected] We will check it and try to update software for better detection process for this firmware. |
11-09-2008, 11:37 | #9 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,423 | Brother thanks for reply but i can't upload 9 Mb file due to internet problem so any other idea to solve this problem ? can i do one thing more that take backup all data ( flash+eeprom ) then whole flash format then write it backup data ? Br Faisal_Computer |
11-09-2008, 12:46 | #10 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,068 | i have also same problem on same model but i return this mobile to *******r after format ffs and full format.and rsult same no changing.it ask code always. |
11-09-2008, 14:05 | #11 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Format full chip = erase full chip. Restore backup = restore original phone content. This way gives you zero results. To check what is wrong with code reading we need to get firmware, look inside and see what is new in this firmware. | |
11-09-2008, 15:46 | #12 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,423 | @ InfinitySupport ok i have Return that mobile to back but i have readed that Flash file so i will try to upload it Tomorrow BR Faisal_Computer |
11-28-2008, 06:11 | #14 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,423 | hi infinity yesterday i got mobile with problem of when i click on Profiles mobile restart i just do format ffs after that mobile said cal. touch screen , but mobile touch screen is demage so i try to Cal. touch screen with software , and on mode 1 mobile not detect , mode 2 its cal. done but mobile still need to cal touch screen ( on mobile screen some thing wrote in CHINESE ) , mode 3 its cal. but mobile still need to cal touch screen ( on mobile screen there is wrote cal. touch screen in ENGLISH after mode 3 ) and last mode 4 its cal. i power on the mobile now mobile not need to cal. touch screen but problem same that when i click/open profile mobile again restart ...... this is really STRANGE problem here is log Please see it , ==== log: [11/27/2008 6:57:06 PM] ==== COM6 [VCP0] selected module v2.66 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: H09A_YLL.RS8347.GC.K0.U1.F3.V05 Version: H09A_YLL_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 168 warning: wrong packet cs 164 of 168 items cleared building list... done 0 items remains Finished, time used: 35 sec Remove/Install battery now ! ==== log: [11/27/2008 6:58:19 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: H09A_YLL_01 Date: MelodyV0.0 Version: ‚ Version: Version: detecting structure #2... 0 1 2warning: wrong packet cs done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 26 sec Remove/Install battery now ! ==== log: [11/27/2008 7:00:55 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: H09A_YLL.RS8347.GC.K0.U1.F3.V05 Version: H09A_YLL_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 1 2 3 done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! ==== log: [11/27/2008 7:01:42 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: H09A_YLL.RS8347.GC.K0.U1.F3.V05 Version: H09A_YLL_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... done 162 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! ==== log: [11/27/2008 7:02:33 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: H09A_YLL_01 Date: MelodyV0.0 Version: ‚ Version: Version: detecting structure #2... 0 1 2 3 4 5 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... done 162 byte(s) read writing data... verification... verification Ok Finished, time used: 44 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/27/2008 7:03:47 PM] ==== COM6 [VCP0] selected module v2.66 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: H09A_YLL.RS8347.GC.K0.U1.F3.V05 Version: H09A_YLL_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items total: 132 items to clear: 132 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs 130 of 132 items cleared building list... done items remains: 0 Finished, time used: 44 sec Remove/Install battery now ! ==== log: [11/27/2008 7:05:02 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: H09A_YLL_01 Date: MelodyV0.0 Version: ‚ Version: Version: detecting structure #2... 0 1 ==== log opened: [11/27/2008 7:06:55 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.66 S/N: 1E6E:0111 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [11/27/2008 7:07:15 PM] ==== COM6 [VCP0] selected module v2.66 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1F03:000F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: H09A_YLL.RS8347.GC.K0.U1.F3.V05 Version: H09A_YLL_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 done 163 byte(s) read Br Faisal_Computer |
11-28-2008, 06:12 | #15 (permalink) | |
S500 strange problem . plz see | amei8141 | Universalbox | 3 | 11-26-2008 22:20 |
<<< Credit lost but nothing happening Please see it >>> | Faisal_Computer | Cruiser Suite | 6 | 11-06-2008 05:42 |
<<< problem with 6500s Please see it >>> | Faisal_Computer | Nokia Base Band 5 ( BB-5 ) | 9 | 10-16-2008 10:14 |
5300 strange problem! pls see below | ReyTech | BB5BOX | 0 | 10-20-2007 11:39 |
Mc922 strange problem. Please read it | Siemens man | Infineon C16X M51 & ARM7 M52 BASED | 0 | 04-04-2002 04:08 |
