06-18-2019, 21:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Tablet fail identify Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6575 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0xE201 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6575 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : OK NAND : 000000000000000000000000 eMMC : OK eMMC : 00000000000000000000000000000000 DAInf: 0 : 0 : 0 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 00000000000000000000000000000000 NAND : OK NAND : 000000000000000000000000 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERROR : 000007D4 : BROM : DOWNLOAD DA FAIL Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-19-2019, 03:16 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6575 will not work in v2 line, because it quiet old and not supported after 17xx line DA. Probably there is something wrong with read security info, try without it and use v1.58 to service it. |
