07-20-2021, 01:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | itel p36 w6501 unlock bootloader Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:37 Operation : Read NVM [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
07-20-2021, 02:50 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | There is NO Bootloader unlock on SPD mate AFAIK, Correct me if Im wrong? Br, xerraco |
The Following User Says Thank You to xerraco For This Useful Post: |
07-20-2021, 12:01 | #4 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | failed Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... >>> Error : UserDetails ( Login or/and PWD ) wrong or empty! >>> Enter User Details in Settings tab first! Reconnect Power/Cable! >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
07-20-2021, 12:36 | #5 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Take a look in logs they're not made for fun Quote:
>>> Enter User Details in Settings tab first! | |
The Following User Says Thank You to yuranc8 For This Useful Post: |
07-22-2021, 15:34 | #6 (permalink) | |
Freak Poster Join Date: Feb 2018 Location: Congo Brazzaville
Member: 2809120 Status: Offline Thanks Meter: 83 | Quote:
solution for this phone have been already provided just search on this forum 1- open spd 2.13 2- choose itel 6501 3- enter your psw and user on setting TAB of spd soft 4- now you can handle your phone , note that u must be connected to internet because this phone need RSA auth from server .... | |
The Following User Says Thank You to leroi2018 For This Useful Post: |
