Huwaei Y541-U02 Unlocking? @JayDi Is it Possible to Unlock Huwaei Y541-U02 with CM2? Best Regards, |
Hello. Upload NVM from this phone. |
I have Uploaded Plz check it. CX_SPDNV - Download - 4shared Code: Operation : Check/Read Info [ v1.11 ] |
any sulution please for unlock |
what is the processor of this phone |
SC7731S , need select correct SLDR for enable it. |
i flashed this phone with sd update but after flash no signal and i try to boot with all possible cpus in cm2 but not booting here is the log Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 1/8/2016 / 6:15:52 PM ================================================== ======= Chinese Miracle II [SPD module] v 1.09 Start at : [1/8/2016 / 6:16:12 PM] Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/8/2016 / 6:16:37 PM] Start at : [1/8/2016 / 6:16:47 PM] Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
Again - read update logs. On PAC selection choose Huawei SLDR. In Manuals all explained. |
waitting for Unlock Huwaei Y541-U02 |
cm2 wont unlock such phone it says phone is aready unlocked, nothing to do. but phone is locked, it is locked by firmware. fimware needs to be patched on this phone. |
