06-21-2009, 06:46 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Infinty Box fail touchscreen reapir at old firmware i have try also chinese miracle 2.82 But always touch screen calibration mode failed. what about your job? you r doing your job as well? you r not giving new updates of new phones. here is all mode all format and operation logs. ==== log opened: [6/20/2009 3:39:43 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.83 S/N: 3FA3:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [6/20/2009 3:40:41 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 85 sec Remove/Install battery now ! ==== log: [6/20/2009 3:42:15 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4 5 6 7 8 9warning: wrong packet cs 11warning: wrong packet cs 12 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! ==== log: [6/20/2009 3:42:36 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 0 1 3 4 5 6 7 8 9 10 11 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! ==== log: [6/20/2009 3:43:08 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4 5 6 7 8 9warning: wrong packet cs 11warning: wrong packet cs 12 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! ==== log: [6/20/2009 3:43:30 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 85 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [6/20/2009 3:45:05 PM] ==== COM9 [Serial2] selected module v2.83 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 158 warning: wrong packet cs items cleared: 158 of 158 items remains: 0 Finished, time used: 31 sec Remove/Install battery now ! ==== log: [6/20/2009 3:45:46 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4 5 6 7 8 9warning: wrong packet cs 11warning: wrong packet cs 12 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 29 sec Remove/Install battery now ! ==== log: [6/20/2009 3:51:02 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 0 1 3 4 5 6 7 8 9 10 11 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! ==== log: [6/20/2009 3:51:45 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 86 sec Remove/Install battery now ! ==== log: [6/20/2009 3:58:58 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 0 1 3 4 5 6 7 8 9 10 11 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! ==== log: [6/20/2009 4:00:13 PM] ==== COM9 [Serial2] selected module v2.83 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 86 sec Remove/Install battery now ! ==== log opened: [6/20/2009 4:08:35 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 3FA3:0112 Wait... Device: Autodetect 6205-6227 NOR Done COM9 ready ==== log: [6/20/2009 4:09:30 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 45 sec Remove/Install battery now ! ==== log: [6/20/2009 4:10:35 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 6 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 20 sec Remove/Install battery now ! ==== log: [6/20/2009 4:11:04 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4warning: wrong packet cs 6warning: wrong packet cs 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! ==== log: [6/20/2009 4:11:25 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! ==== log: [6/20/2009 4:11:47 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 5 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-5)... 0 1 3 4 5 6 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! ==== log: [6/20/2009 4:12:14 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4warning: wrong packet cs 6warning: wrong packet cs 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [6/20/2009 4:12:37 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 3 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 9 8 7warning: wrong packet cs 6warning: wrong packet cs 4 3 2 1 0warning: wrong packet cs error: detection failed (9 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! ==== log: [6/20/2009 4:13:10 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 45 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [6/20/2009 4:14:26 PM] ==== COM9 [Serial2] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F1FA737A.[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_129JBO_CSTAR_EN _FRE_THAI_VIE_RU_V1_3_26B_20071228.BIN_6A2C0188].rpl identification#1 detection finished device-id: F1FA737A identification#1 protocol ver: 04 ver. sw 1: QVGA_PCB01_GPRS_MT6226_S01.SC_7787_129JBO_CSTAR_EN _FRE_THAI_VIE_RU_V1_3_26B_20071228.BIN ver. sw 2: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228, 77FED395 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 04227E22212200:2CEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: QVGA_PCB01_GPRS_MT6226_S01.SC_7787_129JBO_CSTAR_EN _FRE_THAI_VIE_RU_V1_3_26B_20071228__ffs... file saved: G:\(2) Ufs Flasher files\Infinity Box\Backup\ChineseMiracle\QVGA_PCB01_GPRS_MT6226_S 01.SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1_3_26 B_20071228__ffs_20090620-161828.B0E.bin flash: 04227E22212200:2CEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 04227E22212200:2CEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\Q VGA_PCB01_GPRS_MT6226_S01.SC_7787_129JBO_CSTAR_EN_ FRE_THAI_VIE_RU_V1_3_26B_20071228__system_log_F1FA 737A_6A2C0188_20090620-161857.B0X.bin Finished, time used: 258 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [6/20/2009 4:21:42 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 45 sec Remove/Install battery now ! ==== log: [6/20/2009 4:22:38 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 6 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! ==== log: [6/20/2009 4:22:58 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... warning: wrong packet cs 1warning: wrong packet cs 2 3 4warning: wrong packet cs 6warning: wrong packet cs 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [6/20/2009 4:23:17 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! ==== log: [6/20/2009 4:23:38 PM] ==== COM9 [Serial2] selected module v2.82 Action: touchscreen calibration mode: 5 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1AC1:3582 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_129JBO_CSTAR_EN_FRE_THAI_VIE_RU_V1.3_26B_2 0071228 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-5)... 0 1 3 4 5 6 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! |
06-22-2009, 23:11 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Thread closed, no reason to continue. | |
china infinty box files New Firmware Detected here | mastermind_gsm | Infinity-Box | 5 | 01-13-2010 18:16 |
infinty box failed in pakistan | alirose | Infinity-Box | 3 | 01-07-2010 19:38 |
Reverse to old firmware in box | Nokall | HWK | 3 | 01-12-2008 21:55 |
Reapire 6300 New firmware Late Power On seccessfull..! | SHOEB AHMED | Infinity-Box | 1 | 11-24-2007 19:45 |
