06-01-2017, 19:33 | #1 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | I cant not reset FRP MT8127 I can not do FRP reset to this RCA Tab MT8127 Give this error: [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED regards mfeliu07 Quote:
06-19-2019, 16:45 | #2 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Hello I autoresponded after some time, another one came with FRP and I managed to do it. regards. mfeliu07 Quote:
The Following User Says Thank You to mfeliu07 For This Useful Post: |
08-05-2019, 10:36 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Error : Fail to init protocol 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM34) MODE : BOOTROM PORT : 34 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! i want to remove frp from huawei BG2-W09 but where have i gone wrong ? |
08-05-2019, 13:26 | #4 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM47) MODE : BOOTROM PORT : 47 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8127 , SBID : 0x8A00 , HWVR : 0xCA04 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Huawei : TAG Series [ TAG-xx ] | Manual : Enabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8127 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! what am it missing out please help me out |
08-06-2019, 21:43 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,777 | Quote:
AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin How about manually selecting it from right upper corner of main CM2MT2 exe ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
