03-16-2009, 09:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 317599 Status: Offline Thanks Meter: 32 | I find this problem but no solution help infi COM4 [VCP1] selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4D03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:01FEC600000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 0120C6FE0090381C6FF08EFE0C235843284904234018C15E number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ............................................... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:01FEC600000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090316-134144.B0E.bin flash: EC257E25082501:01FEC600000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:01FEC600000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 detect device identification#2 finished Write Fail Finished, time used: 3 I CHANGE CPU FLASH BAUDRATE CHANG FLASH FILE BUT PROBLEM IS SAME THANKS IN ADVANCE |
03-17-2009, 20:50 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please clear: do you use Infinity box and own made cable connected to RJ45 port? I am asking, becuase we had similar problem when other boxes was used as interface. check this tread: http://forum.gsmhosting.com/vbb/show...=428416&page=2 |
Strange problem but no solution yet with N70 | zargar322 | Nokia Hardware & Hardware Repair | 8 | 01-18-2010 06:07 |
infinity team please help me to find this Problem | ahmedasmet | Infinity-Box | 1 | 12-25-2007 19:04 |
old problem but no solution ! | ramzime | Nokia Hardware & Hardware Repair | 6 | 12-17-2005 13:46 |
everybody knows this problem but who can help? | Meam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-10-2001 09:04 |
