03-20-2010, 15:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | i flashed lg b2060 ....after flash set dead..help. B2060P40-91-V10l-XXX-XX_JAN_02_2007_CodeData_w_calibration.B1M after flash set is dead. problem is imei corrupted. |
03-21-2010, 06:01 | #3 (permalink) |
Member: 982335 Status: Offline Thanks Meter: 202 | now the handset is recovered but how to write imei ? full flash with infinity but problem not solved... also write imei in imei box.. COM6 [VCP0] selected module v1.39 Device: LG-B2060 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 3533730100***** current otp imei: 3533730100***** file saved: C:\Program Files\Infinitybox\LGA\eeprom_353373010001307_LG-B2060_20100321-102640.B1E.bin ........ version: XXX-XXV10l91B2060P40 Check flash Done Check space ... current eeprom imei: 3533730100***** Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 31 sec Remove/Install battery now ! but the imei is till oooo? |
LG 8330 after flash set not open | khokonhajigonj | Cruiser Suite | 5 | 06-09-2008 22:28 |
nokia n95 reboot-did format ffs-after it set dead-help | zone2 | Infinity-Box | 1 | 05-14-2008 14:49 |
lg kg300 after flash dead plz help | rajabrotherscom | Infinity-Box | 3 | 05-08-2007 14:38 |
dead lg 5400 after flashing P32-07-xxx.xx V105 Jul 07 2003 | crossings | LG | 2 | 08-30-2004 19:53 |
