07-18-2021, 09:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Pakistan
Member: 437074 Status: Offline Sonork: 100.1604517 Thanks Meter: 53 | I have proble with mt2 2.26 and 2.27 but 2.25 working file but 2.25 working fine Last edited by GGMK; 07-18-2021 at 09:44. Reason: Image upload |
07-18-2021, 09:42 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Remove all USB sniffing and sharing software. COMPLETE remove. they left drivers and services active. Guess - you have usb redirector installed. Remove it. |
07-18-2021, 10:11 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sir, 1. select text at software log window with the mouse 2. perss keyboard Ctrl + C keys 3. Move mouse to forum post window 4. press keyboard Ctrl + V keys After that you will get complete operation log here Thank you! Something like that: If exe was closed you can open file with Notepad: |
07-18-2021, 10:15 | #6 (permalink) |
Member: 437074 Status: Offline Sonork: 100.1604517 Thanks Meter: 53 | Card found : DAC6A378 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! hang here |
The Following User Says Thank You to GGMK For This Useful Post: |
07-18-2021, 10:20 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You can leave v2.25 installed for emergency case. f.e. install it to cL/InfinityBox/CM2MT2-225 And use v2.27 In case of problem you can try with v2.25 Programmers are checking now what may be wrong |
07-18-2021, 10:29 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | use this bat to remove USB share Softwares You need Remove program from Uninstall programs first You need Run as Administrator this bat file for working https://mega.nz/file/vb5gFYpR#qa9nw6...1iz7qhefbUKy_A |
07-18-2021, 10:50 | #10 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | 2.26 fine work Operation : Identify [ v2.26 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : A1K-A12-A31-A32 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03006A22ED774D EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 6955757 ( 0x006A22ED) , MF : 7/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 68C42AF841A23AE6873112E9E5DF11FA DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-05-05 Product Manfct : OPPO Build Time : 29.04.2021 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.57_0570_202104291740 Display ID : CPH2083EX_11_A.57 Display ID : CPH2083EX_11_A.57_210429 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 14 ] Backup path : Backup\MT6765__C5C014810A9686F23F1046A2C5C16EF1\ [28] Read : NVRAM [12] Read : NVDATA [19] Read : PROINFO [29] Read : LK [11] Read : NVCFG [14] Read : PROTECT1 [15] Read : PROTECT2 [17] Read : PERSIST [0] Read : PRELOADER [16] Read : SECCFG [5] Read : OPPORESERVE1 [7] Read : OPPORESERVE3 Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:01:27 |
The Following User Says Thank You to limonbogra For This Useful Post: |
07-18-2021, 11:02 | #11 (permalink) |
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | Card found : 15162424 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03006A22ED774D EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 6955757 ( 0x006A22ED) , MF : 7/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 68C42AF841A23AE6873112E9E5DF11FA DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-05-05 Product Manfct : OPPO Build Time : 29.04.2021 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.57_0570_202104291740 Display ID : CPH2083EX_11_A.57 Display ID : CPH2083EX_11_A.57_210429 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__C5C014810A9686F23F1046A2C5C16EF1\ [1] Read : PGPT Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:31 |
07-18-2021, 13:43 | #12 (permalink) | |
Member: 437074 Status: Offline Sonork: 100.1604517 Thanks Meter: 53 | Quote:
