04-04-2009, 05:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | kp115 100% COM6 [VCP0] selected modulo v1.37 Servicio: LG-KP115 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: unlock Metodo unlock: standard Boot ... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! Conectando, espere... Deje de presionar el boton power ahora ! Flash 01227E22212200:FEEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Seleccionar velocidad ... 115200 Seleccionar velocidad Done Check flash ... current eeprom imei: 011445003349101 Archivo guardado: C:\Program Files\InfinityBox\LGA\eeprom_011445003349101_LG-KP115_20090403-164932.B1E.bin .... Check flash Done Check space ... current eeprom imei: 011445003349101 ................................ finalization done Check space Done Check parameters ... Check parameters Done Borrar: ... Borrar: Done Escribir ... Escribir lock area-1 Escribir Done Finalizado, tiempo usado: 47 sec Quite/coloque la bateria ahora ! |
The Following 5 Users Say Thank You to cdmagsm03 For This Useful Post: |
07-22-2009, 23:01 | #5 (permalink) |
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | [QUOTE=edymata;4680302]which cable can i use ?...is the same lg mg800 (chocolate)?[/QUOT no no is not the same dr.mobilex |
07-25-2009, 16:03 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
TATA WALKY C2 100% Unlocking Solution | kumar_gsm_kumar | Various CDMA/TDMA Cell Phones | 32 | 10-31-2014 06:54 |
NEW VYGISTOOLBOX LG UPDATE: LG KP110,KP115 SUPPORTED - LG Workshop v1.89SC !!! | Gobi | VygisToolbox | 19 | 02-20-2010 16:18 |
NEW VYGISTOOLBOX LG UPDATE: LG KP110,KP115 SUPPORTED - LG Workshop v1.89SC !!! | Gobi | Service Products News & Updates | 0 | 06-14-2008 22:01 |
kp115 when?? | juvenile | VygisToolbox | 1 | 06-13-2008 19:05 |
