i-mobile 510 maybe someone can help me...... i-mobile 510 auto off with simcard. i was do : format, flash firmware, repair eeprom. but still aotup off with sim card. ==== log opened: [2/21/2008 6:28:53 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.10 S/N: Wait... Device: I-Mobile 510 Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM6 [VCP0] selected Action: reset settings Model: I-Mobile 510 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:3F6C:610D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S-7311-THS0-0-R1H Version: FP 60 byte(s) read imei: 35970100271818 connection Ok building list... done items to clear: 181 warning: wrong packet cs warning: wrong packet cs 178 of 181 items cleared building list... done 3 items remains Finished, time used: 49 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! thanks. |
Something goes wrong in ur process,i highlighted with red in ur log.Plz check if good connection established or battery has enough power. Quote:
wrong packet CS ??? ok thanks. but in chinese miracle like N95, i get the same display in process, the phone not auto off. do u know why ??? |
Found this problem before. Try this 1.Full flash and 2.Repair eeprom If not help.maybe hardware problem. Good luck. BR. :) |
@meisam I think I must remove all warnings from softwrae because people absolutley can't understand difference in words "warning" and "error". "warning" means NOTHING SERIOUS. Please, next time read words carefully instead of select it in red color. @dj_t0t4l we have 6 different firmware in support area. try all one by one. You can flash your phone with it and in case of bad results you need to follow last advice from this message: http:///vbb/showpo...57&postcount=4 |
thanks sir, i was try the all firmware in support area R-1H, R-1I, R-1N, R-1O, R-1P and try repiar eeprom 01.B0E, 02, 03, 04, 05 too. when i flash eeprom and do sp unlock, imei was 00000000...... how can i repair imei ??? or this is a hardware problem ?? thanks |
Just look in "service" page and you will see "imei write" button. |
thanks for reply sir, are u sure we have imei write button in service page ?? (i-mobile 510) may be i m wrong sir. thanks |
Yes, I am sure. If you don't have it this means that you have played with dongle settings. Make "search" about "UK-EDITION" option. |
oooo....sorry sir, i m wrong.... just about set UK-EDITION off, and i solve my problem. thanks a lot for a good support from infinity team |
