03-01-2010, 11:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | to all users ..... COM210 [VCP0] selected module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E078:F172 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.246DD875.[E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN_10100B95].rpl rom info detection finished ==================== New firmware detected (v.3.08, database date: unknown): E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 246DD875 rom info ver: 04 sw version: E553_K9F8_E553_GPRS_MT6226_S01.00_0.BIN project-id: E553_K9F8.00.0, 950B1010 code offset: 00000000 ffs offset/size [01]: 00800000/001FF000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? Do you want to use standard ffs/eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make full flash backup for emergency case 3. repeat required operation operation terminated by user operation aborted file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_246DD875_10100B95_20100301-104327.B0X.bin Finished, time used: 1 min 11 sec Remove/Install battery now ! I FORMAT WITH SPIDERMAN AND IS DEAD PLS I NEED FLASH FILE HOPE INFINITY CAN HELP ME |
03-01-2010, 20:10 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashfiles/ChineseMiracle/Anycool/Anycool-D66+_E553_K9F8_E553_GPRS_MT6226_S01.00_0_16m_Ru_Fr _Es_En_De_Th_Vn_Cn_Tr_Hi_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6205-MT6227/eeprom/E553_K9F8_E553_GPRS_MT6226_S01.00_0__eeprom_01.B0E .bin |
to all user and team .. attention pls | THE GREAT ONE | FuriousGold | 7 | 03-30-2010 09:15 |
warning to all users .. someone is trying to steal accounts | strangerboy | Board, Server and Login Problems/Support | 2 | 06-19-2008 23:54 |
Good news to all user and Malaysia user!! | alex12345 | Main Sales Section | 0 | 01-11-2007 07:48 |
vygis ready to now to all users egyption | fonec | VygisToolbox | 0 | 10-22-2004 16:52 |
to all users about imei siemens | komix | x1x to x45/x50 | 1 | 01-03-2002 12:25 |
