02-16-2016, 17:10 | #1 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Tajikistan / Russia-Siberia Age: 30
Member: 1977205 Status: Offline Thanks Meter: 13 | Билайн zte-g r-255 mt625a Is there any chance to unlock ? Code: Operation : Read Flash [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 75 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 0621E5C9264CC19053EF605BCAFF0F74 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 SDS_INFO : 0x007F8000 , 0x00008000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : DESHENG50_6464_11B_TAJIKISTAN_PCB01_gprs_MT6250_S00.TJ-BEE-9D-P150A20V1_0_0B02.bin FileVersion : TJ-BEE-9D-P150A20V1.0.0B02 Saved to : C:\InfinityBox\CM2MTK\Read_out\DESHENG50_6464_11B_TAJIKISTAN_PCB01_gprs_MT6250_S00.TJ-BEE-9D-P150A20V1_0_0B02.bin Done! Elapsed: 00:00:38 Reconnect Power/Cable! please check it if you can DESHENG50_6464_11B_TAJIKISTAN_PCB01_gprs_MT6250_S0 0.TJ-BEE-9D-P150A20V1_0_0B02 |
