04-28-2021, 10:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | i need flash file alcatel 1se 5030u Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : J106_A3_S021_AD_Infinity_Panthere_Pro_V1.0_2019092 4 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2016-07-01 Build Time : 1569291852 Product Brand : android_1 Product Name : Infinity_Panthere_Pro Product Device : Infinity_Panthere_Pro Product Board : sp7731gea Product Manfct : android_1 Board Platform : sc8830 Product Info : Infinity_Panthere_Pro Product Model : Infinity Panthere Pro SECSolution : LEGACY [NS] Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin CODE : modem_wcn.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : logo2.bin CODE : logo3.bin CODE : logo4.bin CODE : logo5.bin CODE : boot.img FSIMG : system.img Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! >>> Error : Flashing failed! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Alcatel Product Device : Jakarta Product Model : 5030U Product Name : 5030U Patch Level : QP1A.190711.020 Display ID : 5030U_ALAP_2SIM_V2.4_20201216_UNLOCK Ver. Incmt : 5030U_ALAP_2SIM_V2.4 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 16.12.2020 Product Info : 5030U Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : TCL Platform Version: MOCORTM_18B_W20.21.5_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W20.21.5 HW Version: sc9863A_modem CMP_Time : 05-22-2020 09:14:00 MODEM TAG : MOCORTM_18B_W20.21.5_Debug_FM_BASE_18B_W20.21.5_sc 9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:25 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 Operation : Read FW [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Alcatel Product Device : Jakarta Product Model : 5030U Product Name : 5030U Patch Level : QP1A.190711.020 Display ID : 5030U_ALAP_2SIM_V2.4_20201216_UNLOCK Ver. Incmt : 5030U_ALAP_2SIM_V2.4 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 16.12.2020 Product Info : 5030U Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : TCL AndroidVer : 10 VlnrLevel : 0x02 SP9863A__10__5030U_ALAP_2SIM_V2.4_20201216_UNLOCK_ _QP1A.190711.020__5030U Read : u-boot.bin Read : sml.bin Read : tos.bin Read : teecfg.bin Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : deltanv_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : socko.img ExtSparse : Compression ratio : 55% Read : odmko.img ExtSparse : Compression ratio : 26% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 44% Read : udc_config.bin Read : phase.cfg Read : super.img Read : u-boot-spl.bin Waiting for device ... hang on log |
04-28-2021, 10:42 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Are you sure it's Alcatel? I can see very similar firmware bt it is named as QMobile Use Firmware File Finder via Telegram @FlashFileSearchBot and enter word Panthere Example: |
04-28-2021, 12:33 | #3 (permalink) |
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | sorry for mistak there is two set logs i need alcatel Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Alcatel Product Device : Jakarta Product Model : 5030U Product Name : 5030U Patch Level : QP1A.190711.020 Display ID : 5030U_ALAP_2SIM_V2.4_20201216_UNLOCK Ver. Incmt : 5030U_ALAP_2SIM_V2.4 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 16.12.2020 Product Info : 5030U Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : TCL Platform Version: MOCORTM_18B_W20.21.5_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W20.21.5 HW Version: sc9863A_modem CMP_Time : 05-22-2020 09:14:00 MODEM TAG : MOCORTM_18B_W20.21.5_Debug_FM_BASE_18B_W20.21.5_sc 9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:25 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 Operation : Read FW [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Alcatel : 5030[D_X] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Alcatel Product Device : Jakarta Product Model : 5030U Product Name : 5030U Patch Level : QP1A.190711.020 Display ID : 5030U_ALAP_2SIM_V2.4_20201216_UNLOCK Ver. Incmt : 5030U_ALAP_2SIM_V2.4 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 16.12.2020 Product Info : 5030U Product Board : sp9863a_1h10 Board Platform : sp9863a Product Manfct : TCL AndroidVer : 10 VlnrLevel : 0x02 SP9863A__10__5030U_ALAP_2SIM_V2.4_20201216_UNLOCK_ _QP1A.190711.020__5030U Read : u-boot.bin Read : sml.bin Read : tos.bin Read : teecfg.bin Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : deltanv_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : socko.img ExtSparse : Compression ratio : 55% Read : odmko.img ExtSparse : Compression ratio : 26% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 44% Read : udc_config.bin Read : phase.cfg Read : super.img Read : u-boot-spl.bin Waiting for device ... |
04-28-2021, 17:32 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | But! You can flash 5030D. It should be on support area. I have no idea, U revision is DualSim or not, but D is dual. X, as remember - single. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
05-10-2022, 14:35 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | File is not found, try google. If you will get it pls upload https://infinity-box.com/?r=100020 Also for best results post here firmware version name |
