I need full flash G6600 Pls i need full flash huawei g6600 vodafone portugal read flash upload rapishare tks |
Hello, G6600 files will be uploaded ion support area ASAP |
i used the flash added to support is still dead |
Hello, What is your phone history ? Why phone become dead ? |
flashes with this link RapidShare: 1-CLICK Web hosting - Easy Filehosting after flash phone dead http://forum.gsmhosting.com/vbb/f296...-info-1013479/ |
Can you post here flash process operation log ? |
COM10 [VCP0] selected module v3.41 Device: Huawei-G6600 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G6600_BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2PT 01V01_04_2010-03-22_En_Pt.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2PT01V01 _04.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0056]: 0020:003600200036 [ST] ST512R3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E5.2PT01V01.04 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2PT01V01 _04.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2PT01V01_ 04.BIN project-id: E5.2PT01V01.04, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2PT01V01 _04.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Disconnect... done Finished, time used: 40 min 58 sec Remove/Install battery now ! |
Use last MModule. try repair security Area. Flash from ASAP work whitout Problems. |
