12-30-2015, 12:07 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | a900 qmobile Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001153030553563FD024D01507A52 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x00000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
12-30-2015, 12:07 | #2 (permalink) |
Member: 1973579 Status: Offline Thanks Meter: 30 | Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001153030553563FD024D01507A52 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
