06-03-2008, 17:17 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200321 Status: Offline Thanks Meter: 2 | I need Help, EZ500 SkyZen. I try Unlock this phone (SkyZen EZ500 by TELCEL). But, the problem is, the software show me this phone "Unlocked", but i insert the SIM card of the other company movil, and the phone is don´t unlocked. Please Infinity Team, Help me. This is the Log operation: ==== log opened: [02/06/2008 18:04:04] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.05 S/N: ***XX Wait... Device: Skyzen EZ500 Done COM7 [VCP0] selected Action: read codes unlock method: read codes Model: Skyzen EZ500 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 42 sec Remove/Install battery now ! COM7 [VCP0] selected Action: read codes unlock method: read codes Model: Skyzen EZ500 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! ==== log opened: [02/06/2008 18:13:35] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.05 S/N: ******X Wait... Device: Skyzen EZ500 Done COM7 [VCP0] selected Action: read codes unlock method: read codes Model: Skyzen EZ500 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 39 sec Remove/Install battery now ! COM7 [VCP0] selected Action: read codes unlock method: read codes Model: Skyzen EZ500 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6218:8B04]... CPU: MT6218 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6218B,E04 Date: 2003.12.29 Version: 1.15.1.5 Version: SL308_PLUS.W05.20.V48 Version: SL308_PLUS_HW 65 byte(s) read imei: 35840100146395 connection Ok 69 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 13 sec Remove/Install battery now ! COM7 [VCP0] selected Device: Skyzen EZ500 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6218:8B04]... CPU: MT6218 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .............................................. detect device identification#1 finished identification#1 protocol ver: 01 ver. sw1: SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN ver. sw2: SL308_PLUS.W05.20.V48 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN]]... file saved: C:\Archivos de programa\InfinityBox\MModule\backup_eeprom[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN]_20080602-181954.B0E-SkyZen flash: B0001D00000000:B0001D00000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... buffer management operation active... buffer management operation finished failed error: probably unknown firmware version, read flash and send to support extra method (auto) in progress... flash: B0001D00000000:B0001D00000000 ............... detect standard fat location pass #1... .................................................. .............. detect extended fat location pass #1... ............... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete required area #1 found required area #2 found required area #3 not detected Finalization Done Write... flash: B0001D00000000:B0001D00000000 Write: lock-area-3 flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finished, time used: 179 sec Remove/Install battery now ! ==== log opened: [02/06/2008 20:38:56] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.05 S/N: ******XX Wait... Device: Skyzen EZ500 Done COM7 [VCP0] selected Device: Skyzen EZ500 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6218:8B04]... CPU: MT6218 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .............................................. detect device identification#1 finished identification#1 protocol ver: 01 ver. sw1: SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN ver. sw2: SL308_PLUS.W05.20.V48 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [flash[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN]_part_1_of_1]... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... warning: wrong data size at 0x00F29C00, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? ==== log opened: [02/06/2008 21:07:23] ==== Application: C:\Archivos de programa\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.05 S/N: ******X Wait... Device: Skyzen EZ500 Done COM7 [VCP0] selected Device: Skyzen EZ500 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6218:8B04]... CPU: MT6218 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .............................................. detect device identification#1 finished identification#1 protocol ver: 01 ver. sw1: SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN ver. sw2: SL308_PLUS.W05.20.V48 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [flash[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN]_part_1_of_1]... file saved: C:\Archivos de programa\InfinityBox\MModule\backup_flash[SL308_TELCEL_PCB01_GPRS_MT6218B_FN.SL308_PLUS_W05_ 20_V48.BIN]_part_1_of_1_20080602-212727.B0X-SkyZen EZ50 Finished, time used: 519 sec Remove/Install battery now ! COM7 [VCP0] selected Action: unlock unlock method: smart fast Model: Skyzen EZ500 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6218:8B04]... CPU: MT6218 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6218B,E04 Date: 2003.12.29 Version: 1.15.1.5 Version: SL308_PLUS.W05.20.V48 Version: SL308_PLUS_HW 65 byte(s) read imei: ***x00******x connection Ok 69 byte(s) read reading data... building new data... writing data... done Finished, time used: 12 sec Remove/Install battery now ! I make FULL FLASH Backup, tall me where i send you. Please i need your help..!! Regars S.S. |
06-04-2008, 01:59 | #3 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 578135 Status: Offline Thanks Meter: 13 | Quote:
06-04-2008, 14:50 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @SSAC70 Please, read full flash from your phone and send to [email protected] to check. Please, include in your mail problem description but not only flash files. @cordd Are you sure that it's 50/50 ? Probably it's 90/10. Yes, some versions has problems, but as I can see it's not 50% and we are working for update our software. |
06-04-2008, 18:30 | #5 (permalink) | |
i hope the upgrade please. greetings | |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
HelloĦĦ i need help for skyzen 700 thanks | UL15E5 | Infinity-Box | 1 | 01-13-2009 18:25 |
Need support for Skyzen EZ700... | -luigi- | Infinity-Box | 12 | 05-19-2008 22:06 |
