i need htc desire 616 dual sim flashfile mt6592 the phone hang on htc here is the log.... Card found : S/N : xxxxxD3 , v0129 Chinese Miracle II [MTK module] v 1.35 Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 58 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3F3256129 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3F3256129 [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! i flash with other rom not work still hanging |
here is tested rom https://docs.google.com/uc?export=do...jZmNHY3c1E0MTQ |
ok thanks i will test and sent result |
Hello, Here is one more link for little help- http://forum.gsmhosting.com/vbb/f296.../#post11130870 Br. |
phone flash but still hanging...... |
Phone come in what problem?? First remove touch and check or try to some heat on cpu Sent from my SM-G531F using Tapatalk |
U try with remove touch?? Sent from my SM-G531F using Tapatalk |
