08-03-2020, 17:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | Need Mione V3 FW BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : J106G_Mione_V3_B15_V001_20191207 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 1575700551 Product Brand : MIONE Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : MIONE Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : Mione V3 Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22 .4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mod em UserData : STATE : PLAIN [EXTFS] Tried format mobile able to access menus later restart started again hang on log |
08-05-2020, 06:59 | #4 (permalink) | |
Member: 2541648 Status: Offline Thanks Meter: 166 | Quote: Your file not accept flash, your file display id is different Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : J106G_Vfone_Moon_B1_V001_20190911 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 1568208582 Product Brand : Qnet Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : VFONE Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : Moon Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update failed! ERROR : 00000084:84000000FF7B7E00 SYS : OPERATION FAILED! Error : Flashing failed! Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! | |
09-24-2020, 10:57 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
