08-06-2016, 10:22 | #1 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2427581 Status: Offline Thanks Meter: 1 | MobiWire AHIGA Firmware AND unlock Needeed is that model not supported Code: Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 129 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 129 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
08-06-2016, 10:42 | #3 (permalink) |
Member: 2427581 Status: Offline Thanks Meter: 1 | hallo i tried that with and without baterry with both vol up and down same problem Code: Wait for phone... Phone found! [ 129 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
08-06-2016, 10:49 | #4 (permalink) |
Member: 2427581 Status: Offline Thanks Meter: 1 | Mobiwire Ahiga Specifications Platform: MT6582M Dual core CPU speed 1.3GHz OS: Jelly Bean 4.2.2 Radio: GPRS/EDGE(Class 12 DL)/ HSDPA(21Mbps) / HSUPA(5.76Mbps) Band: GSM/GPRS/EDGE: 850/900/1800/1900 WCDMA: 900(VIII)/2100 (I) Memory: 4GB + 1GB RAM Micro SD slot (up to 32GB) Battery: 2020mAh Size : 144*72*9.2mm Micro USB – 3.5mm audio jack Touch Keys: Home/Menu/Back Hard Keys: Volume/Power |
