10-08-2008, 10:20 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: UKR
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | Device: LG-300GB Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22102200:FEEA0000000000 flash: Amd AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 current otp imei: 011426003487778 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-300GB_20081008-121827.B1E.bin ........ version: 310-XXXV10c01LG300GHL Check flash Done Check space... current eeprom imei: 350305260000001 ............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 36 sec Remove/Install battery now ! But SIM not valid |
10-08-2008, 10:58 | #5 (permalink) |
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | yes him NET10 in support only 1 file LG300G_LG300GHL-01-V10c_310-000_APR-03-2008_code+alchemy.B1M.bin For phone need only code or code+alchemy? |
10-08-2008, 15:59 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We will try to find more flash files for this model. Also, send eeprom backup file to [email protected] to check. |
10-09-2008, 08:49 | #8 (permalink) |
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | COM28 [Serial2] selected Device: LG-300GB Checking data, wait... advanced flash detection active Action: read eeprom Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22102200:FEEA0000000000 flash: Amd AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... warning: wrong cs at 0x01000C00, retry... error: too many retries during read operation error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 8C .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: E4 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 26 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 .error: wrong answer: 00 . reading[_eeprom-calibration_]... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... error: too many retries during read operation reading[_eeprom-ffs_]... error: wrong answer: 8B error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: 00 error: wrong answer: 00 : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Finished, time used: 49 sec Remove/Install battery now ! http://rapidshare.com/files/152280934/LGA.rar |
10-09-2008, 08:57 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, send eeprom_350305260000001_LG-300GB_20081008-121827.B1E.bin file (should be in folder with module, was created automatically during first unlock attempt) to [email protected] |
10-09-2008, 09:07 | #10 (permalink) | |
Member: 359895 Status: Offline Sonork: 100.107909 Thanks Meter: 137 | Quote:
sent, check your e----mail | |
11-18-2008, 04:45 | #14 (permalink) |
Freak Poster Join Date: May 2006
Member: 273013 Status: Offline Thanks Meter: 47 | COM5 [VCP1] selected module v1.35 Device: LG-300GB Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22102200:FEEA0000000000 flash: Amd AMD/Fujitsu std [B 0008x002000 007Fx010000] 8Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 current otp imei: 011426004604678 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-300GB_20081118-103529.B1E.bin ........ version: 310-XXXV10c01LG300GHL Check flash Done Check space... current eeprom imei: 350305260000001 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 24 sec Remove/Install battery now ! SIM not valid |
11-18-2008, 14:51 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Yes, there is some problems with this phone unlock yet, we are working about it. |
Need Flash File for LG-300G | kashi4gul | Octopus LG/Octoplus LG | 1 | 12-23-2009 15:00 |
I need pinout lg c1300 | johncardenas | LG | 0 | 04-24-2006 22:37 |
I need Pinout Lg G4010 | gabriel2004 | LG | 0 | 02-04-2004 15:58 |
Need pinout LG-510w! | maks | LG | 9 | 12-30-2002 09:53 |
