Old 11-22-2009, 00:14   #1 (permalink)
Member: 389266
Thanks Meter: 17
Full flash ipone p168s
HELLO FRIENDS
I need a favor
I urged a full flash or copy thereof from the "IFONE MODEL NO p168s"
this is the image of cell
http://www.subirimagenes.com/otros-i...s-3597374.html
thanks in advance for their valuable assistance
Note: Sorry about my English
Old 11-22-2009, 00:34   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Originally Posted by engendro View Post
HELLO FRIENDS
I need a favor
hi.
add here fw details...
Old 11-22-2009, 01:59   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, best way is provide "read detailed information" log.
also, in a first place try to solve your problem by format FFS/IMEI restore.
only if this is not helpful- turn to flashing
Old 12-04-2009, 22:06   #4 (permalink)
Member: 389266
Thanks Meter: 17
HELLO
forgiveness for the delay
this is the log of operations "READ Detail Information"
COM5 selected
module v2.90
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:E303:000A
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18A59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detection phase #2...
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device rom info finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
can't detect fat record name location
error: ffs/eeprom detection failed: element #1
Finished, time used: 91 sec
Remove/Install battery now !
thanks for your interest
lucky
Old 12-04-2009, 23:20   #5 (permalink)
Member: 148515
hello!
is this working phone? can you read "general information" from it?
phone must be powered On for this.
Vodafone 332 FM unsuported. Link with full flash stargsm_ro FuriousGold 1 03-29-2010 19:54
Problem Flashing ifoe p168 plz help RazoR888 SpiderMan 2 01-31-2009 23:46
I have V3R full backup file,need Conversion to full flash file phonetool Smart-Clip 12 06-30-2006 07:50
Need full flash and full flex files for L2000 shopen Motorola Old Legacy (EMMI) 0 05-22-2003 06:08
Page generated in 0.15942 seconds with 9 queries
