06-15-2017, 12:24 | #1 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 942 | Huawei G620S can get out of sleep Quote:
Phone will remain off I try via SD Card Update nothing happen I try via XML File , but Module says wrong file Code: Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! Thanks | |
06-15-2017, 14:44 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can extract need files from update app or any other source and flash them via memory tool, for example. |
06-16-2017, 11:14 | #6 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 942 | Quote:
Actually i try that and forgot to mention , I Use EMMC Tool and write mbn files, same thing Looks like some partitions have messed up... Memory tool is some free or payed tool ? Or its same as EMMC DL Tool ? Regards | |
06-16-2017, 11:28 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MemoryTool -> CM2QLM -> Extra -> MemoryTool. Manual can be found in sticky threads. It allow you work with device memory, regions, partitions and e.t.c. |
