I need solution for tecno ca6 dead boot DEAR FELLOW USERS, KINDLY HELP ME FOR THE SOLUTION TO THIS DEAD TECNO CA6. THANKS IN ADVANCE. Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Enabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
If only I had a stable & reliable connection for uploading files I would have uploaded it for you. But don’t give up, the solution there is to write it’s factory signed firmware with tecno aftersales tool. Goodluck Sent from my iPhone using Tapatalk Pro |
I would be very grateful if you can upload for me. Thanks in advance |
Well there’s one on support, have u tried it?? Uploaded since April. Goodluck Sent from my iPhone using Tapatalk Pro |
although i had one signed/factory firmware that i been use to fix many Tecno CA6 but due to dead boot of this particular one the file unable to fix it... |
Thought you had none. Tried through SWD_AfterSAles.exe too? Sent from my iPhone using Tapatalk Pro |
but the tool refused to work on my both pc.... https://i.postimg.cc/RZGzRb5G/Untitled-JMK.jpg |
http://www.mediafire.com/file/and3d0...htool.rar/file Try to run this one [emoji1489] Sent from my iPhone using Tapatalk Pro |
I will try it tomorrow. |
pls upload the file for benefit others Sent from my TECNO G9 using Tapatalk |
I am also having tecno ca6 dead and giving same error while trying to flash it. I have tried two signed firmwares and not solved. If anyone has solved this problem he should please share his solution. Thanks |
