Old 03-28-2008, 12:40   #1 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
nokia n95 flat problem with L12B connector
i have been trying to getTHE RX AND TX OF this n95 (flat) that uses 2x6 L12B connector for some time now with auto adapter,but with no success.but i have use this L12B connector to repair several p910i that uses same connector.so am confused.wot to do now?
Old 03-28-2008, 18:20   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf
Please, see page 19: Automatic pinout detection: Troubleshooting
I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction.
Old 03-28-2008, 20:39   #3 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
i have followed the manual and check everything,is ok. atleast i used the L12B cable to fix one china p910i this morning.
Old 03-28-2008, 20:48   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i guess this phone is not using Tx/Rx pins in system connector.
must be some test points on PCB
Old 03-29-2008, 12:10   #5 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
please how do i locate the testpoint on pcb
Old 03-29-2008, 15:30   #6 (permalink)
Member: 148515
hello!
easyer if you post PCB picture and someone will help you.
also is possible to find needed test points by multimeter, by measuring voltages on all PCB testpoints.
this way is quite tricky, because you must keep phone disassembled, but it still must be powered from battery
Old 03-29-2008, 16:50   #7 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
this the pcb.i hope u can help me
Old 03-29-2008, 19:57   #8 (permalink)
Member: 148515
hello!
as i can see there is huge test point area on your PCB.
one of them must be tx/rx.
lets wait if someone will share with us pinount or i can advice how to find pins by multimeter
Old 03-30-2008, 18:58   #9 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
am still in need of help for this phone
Old 03-30-2008, 19:48   #10 (permalink)
Member: 148515
i can advice to measure voltages on all phone pins and detect needed by voltage 2,7-2,8 volts.
step by step tutorial in our FAQ section under name "second nd test way to detect pinout"
Old 03-30-2008, 20:02   #11 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
i have a phone of this wotking fine, i will test pinout and post result...
Can i repair this problem on nokia N95-8gb only with UFS and how? Boshko_Alfa Nokia Base Band 5 ( BB-5 ) 0 07-21-2009 10:05
Nokia N95 Flex cable with connector and camera at $1x.00 only Transway Main Sales Section 0 02-28-2008 06:21
Pinout For Nokia N95 2 Sim 18 pin connector MarvelXZ Infinity-Box 1 02-26-2008 00:31
N95 Flashing Problem With Mt_box V1.30Beta ccw123 MT-BOX 9 05-02-2007 13:09
Problems with Battery Connector Christobol_007 DreamBox 2 06-15-2006 01:23
Page generated in 0.22269 seconds with 10 queries
