07-13-2017, 21:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Tonga
Member: 2422331 Status: Offline Thanks Meter: 41 | Lenovo FRP remove MT6735 Code: Card found : S/N :xxxxxxxx , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
07-14-2017, 02:04 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | And what model exactly is that ? (The one you are trying to remove FRP) ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
07-14-2017, 02:24 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Nothing to be afraid of. I will post 100% working solution, just waiting for exact phone/device model. b.r. Alex
07-14-2017, 17:46 | #5 (permalink) | |
Member: 2422331 Status: Offline Thanks Meter: 41 | Quote:
Please check | |
07-15-2017, 08:33 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, You can try other way : download SpFlashTool v5.1624 take from it DA_SWSEC.bin rename it to MTK_AllInOne_DA_SP.bin and put in boot folder, but save first original one somewhere. Repeat operation. Br. Infinity Box Team. |
07-17-2017, 18:34 | #7 (permalink) | |
Code: Card found : S/N : 8BE23346 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-06-15.11:02 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! | |
The Following User Says Thank You to ChElEuLaVi For This Useful Post: |
07-18-2017, 00:00 | #9 (permalink) | ||
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
Code: BootLdrSS : LOCKED with SLA Quote:
FRP REMOVE : - Download : Lenovo_TB3-730F_S044_161111_ROW_FRP_Remove_by_bRkA - Unpack archive, Start SPFT from folder \SP_Flash_Tool_v5.1552.00_SecureBoot - Press CTRL + ALT + V in SPFT, (Advanced mode) will appear in window title - Select "Download Agent" - DA_SWSEC_CRYPTO20.bin - Select "Scatter Loading File" - MT6735M_Android_scatter_TB3-730F.txt - Select "Auth File" - auth_sv5.auth - Go to drop-down menu "Options" - "Option", "Download" - select "Usb Checksum" and "Storage checksum" - Go to tab "FORMAT", select "Manual format flash", input : Begin address : 0x6a00000 , Format Length : 0x100000 - Tick "Validation" - Press "Start" (Blue PLAY button), and connect powered off device to cable - It should finish quickly - Disconnect device from cable and power it up. - FRP Should be gone. * In case that you get boot-loop, OR on display written "DL Image Failed", Simply re-flash device with provided rom file below. ROM File : TB3-730F_S044_161111_ROW archive pass : lenovo-forums.ru test and post results. p.s. PAY ATTENTION on MANUAL FORMAT, don't do AUTO FORMAT, you will kill device !!! p.s.2 To be 100% Sure in success, before FRP remove, reflash phone with provided ROM version. p.s.3 CHARGE battery fully before playing with device. p.s.4 For Flashing process, same files must be selected in SPFT - same as for FRP (DA Agent, AUTH, Scatter, USB/Storage Checksum). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | ||
The Following 8 Users Say Thank You to Brka For This Useful Post: |
07-18-2017, 13:28 | #11 (permalink) | |
the ROM link that you give me is not working thanks | |
07-18-2017, 16:21 | #13 (permalink) | |
B.r. Alex
07-19-2017, 20:45 | #15 (permalink) |
The Following User Says Thank You to Brka For This Useful Post: |
