01-26-2021, 07:58 | #91 (permalink) |
Crazy Poster Join Date: Mar 2014
Member: 2138876 Status: Offline Sonork: nawaz Thanks Meter: 4 | Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: USB Smart Card Reader 0 HWID: 0000E77D17004082 === Process started: 1/26/2021 11:49:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 plz help === DongleManager [Infinity] v1.81 [1/26/2021 12:54:17] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: USB Smart Card Reader 0 HWID: 0000E77D17004082 === Process started: 1/26/2021 12:54:17 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 after the update the net was lost === DongleManager [Infinity] v1.81 [1/26/2021 13:15:01] === Searching... Card-Reader: USB Smart Card Reader 0 HWID: 0000E77D17004082 Select Token Type: instead of Infinity-Box/Dongle [CM2] Last edited by YellowBoss; 01-26-2021 at 12:09. |
01-26-2021, 12:10 | #92 (permalink) | |
Result ? | |
01-26-2021, 13:23 | #93 (permalink) |
Member: 2138876 Status: Offline Sonork: nawaz Thanks Meter: 4 | === DongleManager [Infinity] v1.81 [1/26/2021 12:54:17] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: USB Smart Card Reader 0 HWID: 0000E77D17004082 === Process started: 1/26/2021 12:54:17 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
01-26-2021, 13:40 | #94 (permalink) | |
01-28-2021, 20:51 | #95 (permalink) |
Junior Member Join Date: Nov 2009 Location: Turkmenistan
Member: 1164722 Status: Offline Thanks Meter: 1 | hi bro how are you ? please help me after update my friends dongle told mistake === DongleManager [Infinity] v1.80 [29.01.2021 0:46:50] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0002806818201292 === Process started: 29.01.2021 0:46:50 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Disconnected |
01-28-2021, 21:45 | #96 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe More info is here - https://www.infinity-box.com/support/?r=100129 | |
02-26-2021, 13:15 | #97 (permalink) |
Junior Member Join Date: May 2010
Member: 1307507 Status: Offline Thanks Meter: 0 | Help === DongleManager [Infinity] v1.81 [26-02-2021 17:42:58] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 0109A07424881292 === Process started: 26-02-2021 17:42:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
02-26-2021, 14:16 | #98 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe More info is here - https://www.infinity-box.com/support/?r=100129Hello, 1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe More info is here - https://www.infinity-box.com/support/?r=100129 | |
02-27-2021, 07:26 | #99 (permalink) |
Member: 1307507 Status: Offline Thanks Meter: 0 | hel please === DongleManager [Infinity] v1.81 [27-02-2021 11:48:44] === Box/Dongle type selected: Infinity [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0109A07424881292 === Process started: 27-02-2021 11:48:45 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. hello sir still same problem after update driver and change other dongle still same problem please help |
02-27-2021, 22:08 | #100 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager.exe OR 1. Insert Infinity Smart-Card into another Card-Reader (dongle or box). Good result gives Alcor Card-Reader - - 2. Update dongle with Infinity DongleManager.exe | |
03-06-2021, 07:58 | #101 (permalink) |
Member: 1307507 Status: Offline Thanks Meter: 0 | Help === DongleManager [Infinity] v1.81 [06-03-2021 12:20:44] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 0109A07424881292 === Process started: 06-03-2021 12:20:44 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
03-06-2021, 10:54 | #102 (permalink) | |
04-17-2021, 11:11 | #104 (permalink) | |
10-31-2021, 00:00 | #105 (permalink) |
Freak Poster Join Date: Apr 2016 Location: አዲስ አ&
Member: 2558366 Status: Offline Sonork: divanmun Thanks Meter: 11 | == DongleManager [Infinity] v1.88 [31/10/2021 1:59:32 ???] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000B1897F634082 === Started: 31/10/2021 1:59:32 ??? === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
