Old 11-17-2019, 10:55   #76 (permalink)
Member: 1043909
Thanks Meter: 54,518
Originally Posted by motoklet View Post
=== DongleManager [Infinity] v1.72 [17.11.2019 13:35:09] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0024239510461772
=== Process started: 17.11.2019 13:35:09 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
Hello,
This Smart-Card is not an Infinity Smart-Card
- Disconnect all other Boxes and Dongles from PC
- Connect ONLY one Infinity Box/Dongle to PC
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 01-01-2020, 12:52   #77 (permalink)
Member: 1632189
Thanks Meter: 2
please hepl
=== DongleManager [Infinity] v1.72 [01/01/2020 10:18:50] ===
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 000117947D3A4082
=== Process started: 01/01/2020 10:18:50 ===
the problem is efther update smart card please hepl team thanks
The Following User Says Thank You to patonsystems For This Useful Post:
Old 01-01-2020, 19:11   #78 (permalink)
Member: 1043909
As I can see this dongle was updated well today.
Right ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 01-31-2020, 18:21   #79 (permalink)
Member: 2808826
ok a lot of thanks thanks
Old 03-08-2020, 09:55   #80 (permalink)
Member: 894111
Thanks Meter: 8
=== DongleManager [Infinity] v1.72 [3/8/2020 16:52:59] ===
HWID: 00014921FF021982
=== Process started: 3/8/2020 16:53:00 ===
Old 03-08-2020, 10:38   #81 (permalink)
RamSon83's Avatar
Member: 500637
Thanks Meter: 420
=== DongleManager [Infinity] v1.70 [2020-03-08 10:36:27] ===
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0002CDE4FF021982
=== Process started: 2020-03-08 10:36:27 ===
Old 03-08-2020, 13:41   #82 (permalink)
Member: 148515
Thanks Meter: 16,783
Update dongle firmware now ONLY ONCE !
Old 03-08-2020, 15:39   #83 (permalink)
Member: 148515
Old 03-08-2020, 16:37   #84 (permalink)
RamSon83's Avatar
Member: 500637
Thanks Meter: 420
thnx alot
Old 07-12-2020, 20:17   #85 (permalink)
Member: 55104
Thanks Meter: 10
best dongle update
=== DongleManager [Infinity] v1.80 [12/07/2020 23:16:03] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 0103977503EF1292
=== Process started: 12/07/2020 23:16:03 ===
Old 07-13-2020, 10:16   #86 (permalink)
Member: 1043909
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 07-14-2020, 04:18   #87 (permalink)
Member: 55104
Thanks Meter: 10
hi,
i tried to update ,same problem
Old 07-14-2020, 11:09   #88 (permalink)
Member: 1043909
hi,
Do you have special drivers installed ?
Old 07-14-2020, 12:30   #89 (permalink)
Member: 55104
Thanks Meter: 10
DongleManager [Infinity] v1.80 [14/07/2020 15:27:28] ===
=== Process started: 14/07/2020 15:27:30 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 14/07/2020 15:27:52 ===
=== DongleManager [Infinity] v1.80 [14/07/2020 15:27:52] ===
Box/Dongle found: [BEST]
Serial No (S/N): 45949775
Firmware version: 0122.02
=> Activations:
- 00: Infinity-Box/Dongle v0137
- 03: [BEST] v0122
- 07: #7
=> Options:
- Infinity BEST
- Infinity SM
working fine now.thx
Old 07-16-2020, 19:22   #90 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,774
yes, it is very important to install specal drivers for FT 2000 card reader !
Page generated in 0.38120 seconds with 7 queries
