12-30-2015, 04:52 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: indonesia Age: 40
Member: 447517 Status: Offline Thanks Meter: 22 | imei cant permanent.. invalid again after factory setting 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 108 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D036CD82DB94091 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D036CD82DB94091 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 355138044771474 IMEI [01] : 355138044771466 Set IMEI [00] : 355138044771474 Set IMEI [01] : 355138044771466 Prepare finished. Security check required! Wait for phone... Phone found! [ 108 ] Sync... Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just reinsert cable) on this step Reconnect Power/Cable! Operation : Repair Security [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 108 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong Reconnect Power/Cable! |
12-30-2015, 06:16 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Normally - I not use them, sorry. You can use PM. How check VID/PID - right click - properties - then info - Device ID / Path. |
