11-18-2010, 19:15 | #1 (permalink) |
Insane Poster Join Date: Feb 2004 Location: rempart mauritius
Member: 55104 Status: Offline Thanks Meter: 10 | imo T378 lock on telkomsel is it possible to unlock this mobile phone,lock on telkomsel. i've already send backup to [email protected] ==== [11/18/2010 6:02:19 PM] ==== COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:972F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2D0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 24.10.2010): GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1102_TEL K_ST32T3W0_TV_V11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1102_TEL K_ST32T3W0_TV_V11.BIN project-id: GD1102_TELK_ST32T3W0_TV_v11, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1102_TEL K_ST32T3W0_TV_V11__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GOLDDRAGON23D_09B _PCB01_GPRS_MT6223_S00.GD1102_TELK_ST32T3W0_TV_V11 __ffs_20101118-180641.B0E.bin Finished, time used: 4 min 22 sec Remove/Install battery now ! ==== [11/18/2010 6:07:05 PM] ==== COM3 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:972F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: GD1102_TELK_ST32T3W0_TV_v11 Version: GOLDDRAGON23D_09B_HW detecting structure #2... 1 2 3 5 7 8 9 11 12 13 18 19 20 22 24 25 26 28 29 30error: detection failed (20 tries), read flash and send to support connection Ok detecting structure #1... 0 1 3 4 7 8 9 12 14 16 17 19 20 23 24 25 28 30error: detection failed (17 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! ==== [11/18/2010 6:07:50 PM] ==== COM3 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:972F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: GD1102_TELK_ST32T3W0_TV_v11 Version: GOLDDRAGON23D_09B_HW detecting structure #2... 1 2 3 5 7 8 9 11 12 13 18 19 20 22 24 25 26 28 29 30error: detection failed (20 tries), read flash and send to support connection Ok detecting structure #1... 0 1 3 4 7 8 9 12 14 16 17 19 20 23 24 25 28 30error: detection failed (17 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
