Imobile 100 and Imobile 313 Try to read Eeprom and Full flash from Imobile 100 Everything OK.But Imobile 313 NOT. See logs. COM4 [VCP0] selected Device: IMobile-100 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071104-193633.B1E.bin loading data... data loaded Reading [eeprom-sec]... file saved: backup_eeprom-sec_20071104-193635.B1E.bin backup critical area Done Check memory... Reading [flash]... file saved: backup_flash_20071104-195211.B1X.bin Completed Finished, Remove/Install battery now ! Time used: 962 sec COM4 [VCP0] selected Device: IMobile-313 Checking data, wait... Action: read eeprom Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 80FA:8000 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 0000000A backup critical area Done Check memory... Completed Finished, Remove/Install battery now ! Time used: 33 sec |
Reset usercode Imobile 510 Show Error But Work. Usercode clear. See logs. Suggestions Wellcome. COM4 [VCP0] selected Device: I-Mobile 510 Checking data, wait... advanced flash detection active Action: user code unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6226:8A02:8A01]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Identification... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN ver. sw2: 7S-7311-THS0-0-R1N ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: D:\Program Files\InfinityBox\MModule\id.._ARIMA26_05C_PCB01_G PRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN_FFFFFFFF_.rpl warning: unknown identification structure: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN_FFFFFFFF error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN]]... file saved: backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN]_20071029-120959.B0E.bin flash: 98004900000002:29EA0000000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... Finalization Done Write... flash: 98004900000002:457BB500000000 Write: eeprom error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 error: error# 000000E4 error: flash write error: 00FF4000:00002000 Write Fail Finished, time used: 126 sec Remove/Install battery now ! |
Hello, We will check Imobile 313 opeations ASAP. Quote:
2. use "read codes" function |
Thank you InfinitySupport for your suggestions. I will try later.:) |
For references : Imobile 510 Read code Work. ==== log opened: [7/11/2007 12:46:47] ==== Application: D:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v1.66 S/N: xxxx Device: I-Mobile 510 Done Action: read codes unlock method: read codes Model: I-Mobile 510 Checking data, wait... COM4 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S-7311-THS0-0-R1N Version: FP imei: 35970100704xxxx connection Ok Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 2525 Finished, time used: 9 sec Remove/Install battery now ! |
